Tire help!!!!!
Old Oct 4, 2007 | 09:42 PM
quickie4x4's Avatar
Tire help!!!!!
Hey guys,
I need some advice on tires. I have an 04 fx4 screw with 20x10 wheels. I have the stage 1 procomp lift. I am now running 33x13.50 IROK's and want to go with a larger tire. Here are the options I have been tossing around.
1. Go with the Toyo MT 35x12.50 and leave the suspension as is.
2. Go with the 37x13.50 Toyo MT or BFG KM2 and get the bilstein shocks that add 2"
3. Go with the 37 inch Kumho KL71 MT and upgrade my lift with coilovers (procomp or dirtlogic) and crank them up the full 2 inches.
If I go with the second option I would only go with the bilstiens because they are cheaper and the toyos and bfg's are so expensive.
What do you guys think would look the best? Also, with the 3.73 gearing would my truck be a dog with the 37's? I do not want to regear right away. I do have to pull a boat and usually up some burly hills to get to my top secret lake.
Help please!
Thanks,
Quick
Old Oct 4, 2007 | 09:44 PM
keith_bennett's Avatar
Budget? I would get Toyos before i got kumhos. I like number 2. It depends how much money you wanna spend.
Old Oct 4, 2007 | 10:19 PM
djh1121's Avatar
I like number 3...
Old Oct 4, 2007 | 11:27 PM
Get toyos no matter what, you will be happy you did.
Old Oct 5, 2007 | 12:19 PM
wandell's Avatar
If you are not gonna regear, I'd stick with 35's.
Old Oct 5, 2007 | 08:17 PM
11B4V's Avatar
get the Toyo's either way you go
Old Oct 6, 2007 | 12:43 PM
quickie4x4's Avatar
Do you think the 37 x 13.50 r20 Toyo's will rub bad if I add the the bilstein 5100's in the front to add an additional 2 inches? I am not concerned with the gearing as I will change those at a later date.
Old Oct 7, 2007 | 10:01 AM
wandell's Avatar
Yeah, that combo should fit.
Old Oct 7, 2007 | 01:05 PM
djh1121's Avatar
X2...
