2004 F150 Brake Pad change
I'm thinking for the fronts? There should be 2 big bolts holding the caliper bracket and 2 smaller holding the caliper to the bracket. If all the bolts are off the caliper first (smaller head), then wiggling it should break her loose. Usually the caliper comes off easy, it's the rotor that can be a pain. I'm basing this on a 2000 4x4 so not sure how much is different compared to your's.
