Are slotted rotors better than factory?
Old Oct 12, 2007 | 11:58 AM
  #46
ThumperMX113's Avatar
Not to mention the vacuum slots on the Powerslots also help in cooling.
Old Oct 12, 2007 | 02:35 PM
  #47
KHardin1's Avatar
Post Powerslots...........
where are you guys buying these from? Online? What site? Thanks a million!!
http://www.firstgiving.com/khardin
Old Oct 12, 2007 | 09:54 PM
  #48
ToddTCE's Avatar
Vacuum slots? Oh this will make for good reading....right up there with fire slots.
Old Oct 13, 2007 | 12:43 AM
  #49
Yup.
Old Oct 13, 2007 | 01:38 PM
  #50
Steve83's Avatar
Only if you have a microwave transmission & cross-drilled brake lines to match the performance of the rotors.
Old Oct 15, 2007 | 09:44 AM
  #51
02SUPRCRUE's Avatar
Cheapest price I found for Power Slots was at performancepeddler.com. Free shipping also. Picked up 4 Power Slot rotors and Hawk LTS Pads for about $100 less that anywhere else that carried them including Summit Racing.
Thumper you got rid of Raven Riley
02 F150 Super Crew Lariat FX4 White & Silver
5.4 /w Roush Cold Air Intake & K&N filter
3.55 LS
Flowmaster Cat Back
JBA Silver Cat4ward Headers
Rancho RSX's
Rancho Steering Stablizer
Hellwig Rear Anti Sway Bar
Lightning Tails
Outland Sport Bumper Guard
Hella 550's
Silverstars
Superchips 9100 Micro Tuner c/o Troyer Performance
Underdrive Pullies c/o Troyer Performance
Mag-Hytec Trans Pan
Old Oct 15, 2007 | 12:20 PM
  #52
I've heard that Performance Peddler isn't a very good company. Let us know when you get your product and how everything went. I'm still waiting on my left front rotor from Moss Motors.
Old Oct 15, 2007 | 12:48 PM
  #53
02SUPRCRUE's Avatar
Performance Peddler was great for me. I had the front rotors 2 days after ordering, the brakes pads took about 7 days, but I was told the rear pads were back ordered from Hawk. The rear rotors tooks about 2.5 weeks, they were backordered from power slot and I was told that upfront and was asked if I wanted to wait. Once the rear rotors were available, they were dropped shipped from Power Slot in CA. Now that everything is installed I'm very satisifed with the results. The true test will be when the truck is weighed down and I have my trailer on.
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Oct 15, 2007 | 04:37 PM
  #54
I ended up canceling my order for that last rotor with Moss Motors and placed it with Tire Rack, apparently it'll be here in three days. I talked to Powerslot today and apparently they've had the rotors in stock there and shipped out to vendors like three weeks ago but still Moss Motors doesn't have them, wierd.
Old Oct 16, 2007 | 10:41 AM
  #55
02SUPRCRUE's Avatar
Performance Peddler was even cheaper than Tire Rack. Tire Rack was charging over $20. for shipping and the distribution center is less than 50 miles from my house.
3.55 LS
Flowmaster Cat Back
Rancho RSX's
Lightning Tails
Hella 550's
Silverstars
Mag-Hytec Trans Pan
Old Oct 17, 2007 | 05:26 AM
  #56
mitch150's Avatar
Hey KHardin. Try Autobarn.com.
Old Oct 21, 2007 | 11:15 PM
  #57
TNC's Avatar
TNC
Originally Posted by Steve83
Nothing is better than factory. Anything that removes metal from the rotor is bad. Slots helped MANY years ago when pads weren't manufactured as well as they are today, and cross-drilling helps on oversized (racing) rotors, but both only hurt on trucks.
That's a bold statement. I had my rotors drilled on my '97 and they were much better than factory. They also lasted, within tolerances for the entire (149Kmiles) time I had the truck. No brake fade, and I went nearly twice as long between pad replacements. Don't forget , all manufacturers look for the best combination of quality and cost. Not necessarily the best part at any cost. Brembo or Powerslot rotors are very high quality. Put Brembo's on my wifes Benz and they are way more robust than the stock MB parts. When mine wear, I'll drill if possible, otherwise I'd go for the higher end aftermarket parts.
Old Oct 23, 2007 | 01:44 PM
  #58
YOMAN's Avatar
Whats different between Cryo and regular slot rotors?? Which one is better for daily driver and ONCE A WHILE towing ??
Thanks!
YOMAN!
Old Oct 26, 2007 | 12:14 AM
  #59
theman86_2's Avatar
Is there an advantage of cross drilled over slotted or vice versa?
Old Oct 26, 2007 | 11:37 AM
  #60
2stroked's Avatar
Oh man! Please go back and re-read this entire thread. Hint: The answer is "yes" - but only if you use Metric Brake Fluid.
