Tire size Change
Tire size Change
Ok guys here is the question. Currently on the truck is a 255/70/17. If I put a 265/70/17 on will I need to have my speedo and tranny recaled? Im looking at the Pro Comp All Terrains. Thanks for your help. I have talk to a few shops and they say that it could cause some issues with the computer but there not sure. Thanks for the help.
It's a taller tire, so your speedometer and odemeter will be off. Get a tuner, it will correct it and provide much more performance too.
a few good tire sites, enjoy
http://swatt.j.porter.name/tech-cent...ire-calculator
http://www.discounttire.com/dtcs/infoTireMath.dos
http://www.bmwtips.com/tires/calc.htm
http://www.car-videos.com/info/tirespecs.asp
http://www.tirerack.com/tires/tiretech/tirespecskey.jsp
http://www.1010tires.com/WheelOffsetCalculator.asp
http://www.dakota-truck.net/TIRECALC/tirecalc.html
Originally Posted by kingfish51
No need to reprogram for that small a change. Difference is just over 1 mph.
Originally Posted by APT
Just to be clear, the change is relative, so it will be a percentage off. 1 MPH @ 60mph, 0.5mph @ 30mph, 1.5mp @ 90mph. Likewise, the odometer will read lower by 1.77%. So, for every 1000 miles your odometer tells you, you actually drove an extra 17.7 miles.
Would I be able to bring the truck to ford and have them recal the computer? The only reason I ask is because I have to sign a form stating that the odometer is correct when I trade it in. I haven’t purchased the tires since im waiting for them go on sale in Oct. buy 3 and the 4th free from pro comp. Thanks again for all the help. I didn’t know that going from a 255 to a 265 would make such a change. I guess it all is relative to the .1 difference in the height.
kingfish51 that is correct on the 80 bucks just called one of the local dealers and that is what they said. 80bucks if they can reprogram it. Kind of odd that they dont know if it can be fixed. You would think that since ford likes to use these odd ball tire sizes they would expect this. Although i guess its not just a ford issues guess alot of the car companies like to do that. Thanks again for all your help. I like the pro comps because there actually a truck tire rather then a car tire. Im not looking to buy a programmer for a one time use so I guess ill pay the 80 to ford, plus that means that I can screw up the computer.
