Need help real quick... Tire size???
I ordered some wheels a few weeks ago and I ordered the moto meltal 951
20X9 with 30 offset. I ordered 285/55-20 tires and the company sent 305/50-20s. The guy at the shop says that they will fit. My question is WILL THEY? 2006 f150 4x4 stock height.
x2 Really tight
Wheel height has changed by about .25" (technically, but maybe not at all) and the width by a little less than an inch. But now you're 2" wider than stock tires. That +30 offset (which is a useless measurement) gets you 5.5" backspacing, which is OEM, so you're good there.
See if your guy will back up his claim. Mount one tire, put it on the front and lock out the steering. Will he send them back if it rubs?
If I were you I would scrub that deal. Get a leveling kit and go for the 305/55/20's or bigger
But if you stick with what he is offereing the only real difference would be that the 305 is about 3/4 of an inch wider.
The 305 is smaller in every other aspect.
Just as a reference heres how mine sits with the 305/55/20 & level kit
The 305 is smaller in every other aspect.Just as a reference heres how mine sits with the 305/55/20 & level kit
