Carquest blue brake pads revisited
Guys,
I know there has been some talk about how good the Carquest semi metallic blue pad are vs OEM. I was just wondering if anyone has tried the their Ceramic blue pads as well. When you call these Carquest stores they will inform you right away that if you want less or no brake dust, then the Ceramic blues are the way to go, not semi-metallic.
Just curious if anyone has used the ceramic versions. I know one person on here does, but I do not have PM privileges it would seem because I don't have enough posts or some bogus reason to that effect.
Thanks,
Tom
Thanks,
Tom
i installed the ceramic blue carquest pads just a couple of weeks ago. they seem to work as good or better then my orginals. only time will tell how many miles i'll get out of them and how hard they are on the new rotors. i was told the factory ones on my 03 supercrew 4x4 were ceramic. if that was the case then i should easily get 50000 miles on these as well (hopefully). so far i like them.
Man, I'm telling you it's retarded how little I get, after weeks and normal conditions, maybe rain one time it is almost not noticed even after rubbing your finger down it. There always will be some, but I've seen the Lord and he handed me these pads. I don't have the invoice right here to get a part # but I've always gotten second to most expensive at Carquest, BMD711 I'm sure the number is, the ceramics were twice the price and GMD711, B for "blue" and G for "gold" is how I remember them. I have a box downstairs, I keep the box in case of warranty and it says semi-metallics.
