What size
Old Apr 18, 2007 | 08:26 PM
bendixx's Avatar
What size
'05 screw, 2" AS level kit, 17" stockies.... What would be the largest size i could fit on those 17's... and what IS back spacing and will i need to do it?
Old Apr 18, 2007 | 10:22 PM
wandell's Avatar
If you have a 4x4, you can fit 315/70-17's (35x12.50). If you have a 4x2, I'd stick with a 305/65-17 (33x12.50).
Backspacing is simply a measurement, it's not an automotive part. It's the distance from the mounting surface of the wheel (where it bolts to the hub) to the rear edge of the wheel. Your OEM wheels are 17x7.5 inches wide and they have 5.5 inches of backspacing.
Old Apr 19, 2007 | 07:47 PM
bendixx's Avatar
Ok so this will affect how far the wheel goes in to the wheel well an how far it sticks out from the flair.... so when buying rims how much backspacing shoud one have?
Old Apr 19, 2007 | 08:01 PM
wandell's Avatar
Exactly. However, keep in mind wheel width and backspacing are as important to tire fitment as tire size. So, if you go to a wider aftermarket wheel, that changes what size tire you can fit. If you go with an aftermarket wheel, you will have to go with a slightly smaller tire unless the new wheel is identical to the OEM specs (7.5 inches wide with 5.5 inches of backspacing).
Also, you never said if you have a 4x4 or 4x2.
Old Apr 19, 2007 | 08:15 PM
bendixx's Avatar
Sorry.... 4X4.. so if I go to an 18" Rim what size should I do or should I ask when i go in to get them?
Old Apr 19, 2007 | 08:23 PM
wandell's Avatar
I'd suggest going with a 325/60-18 (33x13.00) tire with an 18x9 inch wheel with 5 to 6 inches of backspacing, depending on how far you want the tire/wheel to stick out. A 9 inch wide wheel with 6 inches of backspacing will stick out an inch farther than your OEM wheels, 5.5 inches of backspacing will stick out 1.5 inches farther and 5 inches will stick out 2 inches farther. This is a great looking combo on a 4x4 with a leveling kit and the 325/60-18 is a common tire size.
Old Apr 19, 2007 | 08:37 PM
bendixx's Avatar
Thanks... Now I have an idea what to do..... Now I just need more money.
Old Apr 19, 2007 | 10:46 PM
Penny&Cents's Avatar
Question Can I jump in here with a question?
I have a 4x4, and I plan to install either a 2" or 2.5" leveling kit, and possible a 3" block on the rear. I have the stock 20" wheels. Can I put a 35/60/R20 Toyo TOYO Open Country MT 35X12.50R20 121Q E10 or a TOYO Open Country MT 33X12.50R20 114Q E10 w/o causing rubbing? I believe that the stock rim is 8.5" in width. I think the backspacing is approx. 6"
Old Apr 20, 2007 | 02:38 PM
wandell's Avatar
Yes.
Old Apr 22, 2007 | 10:37 AM
Thank you!
Old Apr 26, 2007 | 08:30 PM
Ford460Redneck's Avatar
Quickie
Got a bone stock 98 150, 4.6L with OEM 17's. Currently has 265/70's on it. I wanna go bigger. How big can I get away with with out rubs. I don't mind tires sticking out at all.
Old Apr 26, 2007 | 09:15 PM
wandell's Avatar
Without any rubbing at all, a 305/65-17 (33x12.50)
Old Apr 26, 2007 | 10:08 PM
Thanks! What tire do you recomend? Looking for something aggressive, but still good for the street. Won't kill the gas milage and wear out after 20,000.
I am gonna keep the stock rims for a bit longer, due to lack of total funding.
Old Apr 27, 2007 | 03:49 PM
Can you recomend a good leveling kit too?
Old Apr 27, 2007 | 07:32 PM
What do you think of these in 22, wrapped in Nitto 420's in 305/40R22
