Brake help
Old Apr 2, 2007 | 01:11 PM
nasty3g's Avatar
Brake help
Hows everyone doing, i have a couple fo questions about my 97 f150 stepside....4.6 v6 auto trans
ok i got into my car and my shifter wont shift out of park. I figured i blew the shift interlock fuse and i checked it....that wasnt the problem. I checked the break pressure fuse and it was blown. I go to replace the fuse and it blows right away. This fuse controls my brake lights and i was wondering if anyone has had this problem or if you know how to fix it
thanks....
Old Apr 2, 2007 | 07:35 PM
F151's Avatar
Sounds like a short.........may be in the tail light housing, in the bulb socket. This is a common place for corrosion. Post this in the electrical forum for more educated responses.
Old Apr 2, 2007 | 10:21 PM
99Txtruck's Avatar
Maybe a brake lite switch???
Check the brake light switch, could be internally shorted, and/or the harness wire could be exposed shorting to ground blowing the fuse...
https://www.f150online.com/galleries....cfm?gnum=7516
