36 x 14.75 x 18 tires with 6" lift
Old 02-13-2007, 03:06 PM
Mastacator's Avatar
I have a 2005 4x4
So I am hoping to get a 6" fabtech lift.
The tires I've got my eye on are 375/60R18 MT Baja Claw Radials. See Here
I'm just wondering what 18" wheel will work best with these. Moreso wondering the dimensions for backspacing and offset that I would likely have the least problems with.
Or is it even possible with a 6" lift, would I need a little more lift?
Any thoughts on the combination?
Thanks!
Old 02-13-2007, 08:28 PM
Mastacator's Avatar
Oh come on people!!! No input at all?!
I know everyone has got an opinion, spit it out!!
Disclaimer: Whatever opinion or advice you give me I won't take as gospel and buy whatsoever wheel you tell me, and I won't lay blame if I do buy a particular wheel that ends up not fitting right.
Old 02-13-2007, 08:35 PM
wandell's Avatar
I think you need more lift. As for a wheel, I'd want at least a 10 inch wide wheel with a tire that wide. As for backspacing, I'd stay around 5.5 inches.
Old 02-13-2007, 08:44 PM
djh1121's Avatar
I believe u would rub. You could either get the Fabech coil-overs and crank them up a little or a body lift. You could add a spacer, but I'm not telling u to do that. It’s your call...
Old 02-13-2007, 11:41 PM
Mastacator's Avatar
Thank you. Needing more lift is what I was afraid of.
Wandell, your knowledge is always appreciated.
Thanks for the ideas dj, I was going to get the kit with the coil-overs.
Quick Reply: 36 x 14.75 x 18 tires with 6" lift
