7.5 Wheel
Old 01-17-2007, 07:09 PM
06flamefx4's Avatar
Question 7.5 Wheel
Im going to get 35x12.5 soon. Im going to mount them on my stock 18's. The wheel is 7.5in and the recommanded width is 8. What is the worse that could happen with mounting them on a smaller recommanded wheel. THANKS
Old 01-17-2007, 07:31 PM
Missouri_FX4's Avatar
you'll be just fine with that combo. many people are running that same set up on their trucks around here.
Old 01-17-2007, 10:00 PM
06flamefx4's Avatar
yea i know. i just didnt know it is would be hard balancing or the tire would bubble or wear funny.
Old 01-17-2007, 10:09 PM
Mange's Avatar
They may bubble and cause center wear. Worst case scenario would be if you aired them down to 4x4...they could break off the bead on rough terrain.
Old 01-17-2007, 10:22 PM
wandell's Avatar
Actually, it is much harder to pop a bead when using a narrow wheel vs. a wider wheel. That's why rockcrawlers run narrow wheels. Worse case senerio, the center portion of your tire's tread will wear slightly faster than the rest, similar to running too much air pressure.
Old 01-18-2007, 02:52 PM
06flamefx4's Avatar
Well do they make a wheel that is a 18x8 that is almost the same specs as a factory fx4 wheel.
Quick Reply: 7.5 Wheel
