$30.00 Mounting & Balancing a 35" Tires
Old Nov 16, 2006 | 07:51 PM
MrToyMan's Avatar
Hi,
I have a set of a Never Mounted 35X12.5 R18 Toyo Open Country MT that needs to be mounted and balance on a Brand New Set of Procomp Series 6005wheels. Tires &wheels were purchased from a private party and online.
I've called around the Los Angeles Area Local Tire stores(America's Tire,BigOtires and others) and almost all will charge from $26.00 to $30.00 each to mount & balance plus $3.00 to 5.00 each for the chrome valve.
Is this a fair price, i think( but not too sure)i've read here somewhere that it should only cost $10.00 to $15.00.
Old Nov 16, 2006 | 08:43 PM
bud8817's Avatar
thoughs prices sound about right.
Old Nov 16, 2006 | 08:44 PM
BalogUK's Avatar
30/corner??? i'd settle for 26-30 all said and done... shops around here will do it for 15-20 total...
Old Nov 16, 2006 | 09:56 PM
Dog'em's Avatar
That price sounds about right. I did the same thing last month. For $120 I bought chrome valve stems, different lugs and had the tires mounted and balanced along with installing some ceramic brake pads.
Old Nov 16, 2006 | 11:11 PM
racerf150-2's Avatar
i work at sears and out price is 13,99 a tire mount and balance but that comes with free rotate and balance for the life of the tire also
Old Nov 17, 2006 | 12:43 AM
GrnXnham's Avatar
Yep, bigger tires take longer to balance so they charge more.
Old Nov 17, 2006 | 12:59 AM
Duffman0286's Avatar
cost about 10 a tire over here alot of places around here charge around that
Old Nov 17, 2006 | 02:22 PM
truckinghard11's Avatar
sAM'S
GO TO Sam's Club or Costco.
**** Big O,
THEY RAPE PEOPLE
$35 is crazy.
It's no harder to balance aggressive 35's than it is to balance agressive 285's.
$9 dollars each at Sam's
Or Free if you slip the kid a 20 when their slow.
Seriously get em when their slow pull a kid aside and make the offer . I've done it several times. To someone makeing 9 an hour a 20 is a lot. If you r really happy with the job give em some more later and make a point to have it done regularly. I had regular clients that I balanced under the table for some scrill on the side.
35's will balance fine there, 37's might melt down the machine
The cost of a membership $35 easily pays for itself. Or free if you can set something up. Jus tbe cool. and i'm sure they'd be stoked to just get to work on the rollout.
My store always did a good job.
Truckin
Old Nov 17, 2006 | 03:10 PM
Trooks2001's Avatar
Goin rate around here is $10-$15 a tire.
Old Nov 19, 2006 | 10:29 PM
MrToyMan's Avatar
Thanks for all the responses, highly appreciated. I did have it mounted and balanced today for out the door price of $100.00 for the set including chrome valves and something extra for the guy who did all the work.
Everything is happening as planned and just waiting for the Rize dealer's call to install the 6" lift i ordered.
Old Nov 19, 2006 | 10:41 PM
Dog'em's Avatar
Should look sweet.
