Nitto 325/65R18 Tera Grapplers
minor rub
I am very new, this is actually my first post. But I have experience when it comes to 4x4 trucks. The NITTO's are very good tires and will work on your truck stock if your truck came with the rubber insulator that comes on most FX4's and hlf of the stock 4x4's. If you want to go with a aftermarket rim try to get on that is 4.75 backspacing and you will have no rubbing on the upper control arm or frame. I have seen and tryed both on my truck
Originally Posted by tdm4727
Tonka,
Thanks for the help...So what type of trimming do you think you need? Just the Plastic fender flare? Is the rubbing bad enough where you are going to trim? Id like to see some pics if you do.
Offset is the biggest concern.
The Company that Tonka purchased the wheels from does extensive testing to insure that the wheels will work. DTC has several wheels that are a 18-20 mm possitive offset that work great. The tire is oversized for the application but with some care,( don't hammer it offroad with suspension articulation) it will work. To see the current styles available go to tires.com.
Tonka, I would like to see pictures of the trimmed area too. I just ordered the same tires Tonka has excpet they are on Eagle 186's and they do not clear , even with a 2 1/2" leveling kit. It really hangs up on the fender well where the flare comes down-almost yanked the whole flare off. I trimmed the valance and that cleared up it catching on the front-it is back that is the bugger. This is on an 06' FX4.
(Tonka, I forgot about this thread before I emailed you)
Originally Posted by zsommer79
Relamancer, I would tell the guy to shove those goodyear's where the sun don't shine. I have had brand new goodyear tires split and lose tread, now how is that a upgrade? In my opinion Goodyear spends a ton on advertising just to make people feel good about buying a crappy tire.
I agree goodyear tire one big reasons we get strandin out in hot spots in iraq a they get good marines killed tire split apart loose tread and blow all the time dont buy goodyears
