Nitto 325/65R18 Tera Grapplers
#46
Hey guys...I just got the AS 2.5" level kit installed today, and couldnt bear the stock tires for another hour. I went straight to discount tire and got the Terra Grappler 325-65R-18 (35x13.5x18) mounted on MB Motoring 18-8.5" wheels (25mm backspace). I had them test fit one, and the only rubbing is on the back plastic wheel well, and it is flexible there anyway. The tire is exactly flush with the stock FX4 fender flares, which is what I was looking for. I am going to have it aligned tomorrow, so that might change a little bit. So far im pretty happy, and I'll post pics as soon as possible.
#48
#49
Originally Posted by SVTErick
Guys I have a 4x2 with a Skyjacker 3" lift. I am going to be adding either 325/60 (33.4) or 325/65 (34.6) to my 18" FX4 wheels. Havent made up my mind yet, but I want to know more about the rubbing on the upper control arm. Can anyone clarify. I can certainly clear 35's.
I just had 325/65 r18 put on my stock rims and the tires did rub a little on the upper control arm. Just take a grinder and take a little off the control arm like I did and you won't have a problem. Be careful not to take to much off though.
#50
#52
#53
Originally Posted by grapeape
The Company that Tonka purchased the wheels from does extensive testing to insure that the wheels will work. DTC has several wheels that are a 18-20 mm possitive offset that work great. The tire is oversized for the application but with some care,( don't hammer it offroad with suspension articulation) it will work. To see the current styles available go to tires.com.
Tonka - what company did you buy your wheels from?
#57
Tonka and I have the same setup now. I got my wheels and tires from Discount tire. They are a little past flush with the fender flare, and do stick out probably 1.25"- 1.5" more than the stock wheels. My stock wheels set inside the fender a little bit. To my knowledge I have had no rubbing on the control arm, but am having some rubbing on the black plastic inner wheel well. I am going to trim it today, and expect that to clear it up. Hope this helps.
#58
