tread width
Old Oct 31, 2006 | 04:31 PM
kingfish51's Avatar
Correct. Sorry wandell but you are wrong on this, This is one of the most common missconceptions about tire sizing. APT is correct. its how wide the tire is from wall to wall on the outermost part of the bulge. Only way to figure out the tread with, besides measureing would be if its a 70 series tire, that means 70% of the tire is side wall. So if you know the sidewall height you can go from there.
See vvv nominal width of tire in mm, not tread width
http://en.wikipedia.org/wiki/Tire_code
-Patrick
After looking it up, I agree, however, whatever the tread width is, it is not going to change because the wheel width changes. If it is 11 inches on a 8" wheel, it will be 11" on a 9 or 10" wheel.
Old Oct 31, 2006 | 04:44 PM
correct, but there are maximum widths, and minimum widths for each rim width. You can't put a 325 tire on a 14x6 rim etc.
-Patrick
Old Oct 31, 2006 | 04:56 PM
kingfish51's Avatar
-Patrick
There are some around here that would.
Old Oct 31, 2006 | 09:24 PM
fordsoldier's Avatar
Originally Posted by APT
285mm is the section width, not the tread width. Tirerack nor BFG web sites list tread width. I'll measure mine tonight, 285/70R17 on OEM 7.5" wide rims. Different year truck, but a 7.5" rim is 7.5" wide.
APT was wondering if you had a chance to get that measurement for me. It is greatly appreciated.
Old Nov 1, 2006 | 07:25 AM
APT's Avatar
APT
Sorry, man. Busy evening with Haloween and trick or treating. I'll set a reminder on my phone for tonight. My F-150 hasn't been my daily driver lately, or I'd go measure it now.
Old Nov 1, 2006 | 08:26 AM
thanks for the help APT
Old Nov 1, 2006 | 05:52 PM
APT's Avatar
APT
9 1/8 inches
