2.5 with 35's
Old 10-09-2006, 05:54 PM
05Blue150's Avatar
Lightbulb 2.5 with 35's
I know there has been much talk about this and i have found some trucks on the site that have this done on OEM rims..
I just ordered the autospring 2.5, and now looking for 35x12.5's . am i limited on brands due to rubbing and fitment on OEM rims or can i go with a nice mud tire. I dont use my truck as a daily driver so im not to worried about uneven tread wear but more about rubbing..
All help is appreciated..
Old 10-09-2006, 11:13 PM
spinnintires's Avatar
it all depends if you have a 4x2 or 4x4. If you have a 4x4 you can get away with 35's but if you have a 4x2 you can only do 33's unless you add a body lift or suspension for additional clearance.
Old 10-10-2006, 08:02 AM
wandell's Avatar
Right. Also, do you have 17 or 18 inch wheels?
Old 10-10-2006, 04:59 PM
05Blue150's Avatar
i have a 4x4 ext cab, with 17x7.5 i belive...
I was thinking of going with the MT baja claws 35x12.5/17 or maybe the nitto muds
Old 10-10-2006, 05:06 PM
BalogUK's Avatar
you should be fine- when you are looking make sure you stay (within an inch-inch.5 ) to the suggested rim width- ie, tire-A 35x12.5 approved for rims 8.5-10" stock is 7.5" that'll work. tire-B 35x12.5 approved for 9.5-12" rim thats 2" off the stock 7.5's and not exactly a safe bet...
Old 10-10-2006, 05:15 PM
05BLUE150,
If you have 17" factory rims +the AS 2.5" then you can put 315/70R17 BFG A/T on with minimal issues. I have that exact set up on my '06 SCrew and the only rubbing I had was on the drivers side inner (black) fenderwell ~ that was easily resolved by trimming 1" off of the bottom edge towards the back of the truck using a boxcutter knife. It only rubbed when I had the wheel turned full right while backing up. I'll try to post a few pictures of my truck...
Old 10-10-2006, 05:39 PM
05BLUE150,
Try this link to my gallery:
https://www.f150online.com/galleries....cfm?gnum=8450
flyfish_addict
Old 10-12-2006, 10:37 AM
05Blue150's Avatar
Thanks for the info, i am looking for a more aggressive look then the BGF A/T's but i will keep an eye out for the 315's. That is the same tire as a 35x12.5?
Old 10-12-2006, 02:46 PM
wandell's Avatar
A 315/70-17 is the same as a 35x12.50-17. If you want something more aggressive, the Pro Comp MT is available in 35x12.50-17 and the Goodyear MTR is available in 305/70-17 (34x12.50-17).
Old 10-12-2006, 09:18 PM
05Blue150's Avatar
Found the tires i want http://www.procomptires.com/xterrain2.html 35x12.5x17 and the suggested rim width is 8-11 so i should be fine right?
anyone know how many miles il be able to get out of these and will it hum louder then the flow 40's ??
Old 10-13-2006, 11:49 AM
BalogUK's Avatar
ive got the Xterrains on my stockers right now- they are wearing perfect @ 40 psi front and back, and overall wear is minimal so far 7,000 miles on them-mixed use. they are louder than the toyo mt's (all i can compare to) but not obnoxious by any means
edit to add- Mine are the 3ply sidewall though i'm on 18's
Old 10-23-2006, 12:08 AM
ktexas's Avatar
bigger tires
I have stock 18" FX4 rims I want the biggest tire I can fit on them. Am I looking at a 305/65/18, 315/18 or 325/18. BTW I have leveled the front I think 2" with some car quest coil inserts.
Old 10-23-2006, 12:23 AM
BalogUK's Avatar
ok, you've got the FX4 wheels, but are you an FX4? lol
if you are a 4x4, you can fit 35's on the stock wheels with a 2-2.5" spacer
if you are a 4x2 with fx4 wheels, you can fit 33-34" with a 2-2.5" spacer
Old 10-25-2006, 10:41 PM
ktexas's Avatar
Yes I have the FX4 wheels on a real FX4 truck. I'm just torn between 325's or 305's. One is wider and one doesn't lose as much perf. Maybe that tuner I want is gonna be more important after all.
Old 10-27-2006, 10:55 PM
ohiodave150's Avatar
anyone try 35x12.50 on the 20" OEM rims? the new 20" OEM rims are 8.5" wide.. would that be better or worse for rubbing issues with 35"'s??
Quick Reply: 2.5 with 35's
