Question on Tires and Wheels
Old Mar 26, 2006 | 12:07 PM
SuperCREWZZZER's Avatar
I am getting new tires and rims, and I did some searching for what would look good, what would fit, and what I want. This is what I came up with. But I also have one more question in an 01 Screw what is the smallest rim hieght due to the brakes and everything. But basically I am looking at about a 18-16x10 rim with 4.5 backspacing with a 33x12.5 tire to match the rim. Does anyone see problems with this, I do not mind trimming a little bit of plastic. Also how far will these tires stick out past the edge of the fender flare. Thanks in advance Sorry one more stupid question or atleast making sure of something, but what is my bolt pattern for my lugs.
Old Mar 26, 2006 | 01:35 PM
KickinBlue4x4's Avatar
My personal opinion, is that I would not go with x10's. They stick out a lot and you cannot seem to keep your truck clean. My x8's stick out plenty for me, just make sure you get a good amount of back-spacing.
Old Mar 26, 2006 | 03:56 PM
wandell's Avatar
You are right. A 33x12.50 on a 10 inch wide wheel with 4.5 inches of backspacing will fit with only minor trimming of the front bumper's lower plastic valance. Also, you have to use at least a 16 inch wheel to clear your brakes. Here are some pics of mine with 16x10's and 285/75-16 (33x11.50) BFG's. The edge of my tire/wheel is just about even with the edge of the fender flares.
Old Mar 26, 2006 | 04:33 PM
Silver05's Avatar
With that 10 inch wide rim you have Wandell it kinda looks like your tires are buldging out a bit. Is that normal?
Old Mar 26, 2006 | 05:38 PM
Thanks alot for the help
Old Mar 26, 2006 | 08:36 PM
NWAF-150's Avatar
almost all manufacturers recommend a 9-10 rim for a 33 12.50 just get the right offset and backspacing and you will be fine a 12.50 on a 8 rim will balloon out alot
Old Mar 29, 2006 | 03:20 PM
NateRW21's Avatar
Wendall's tires are normal... the balloning is normal for the tires he has on there (BFG All Terrains)
Old Mar 30, 2006 | 08:37 AM
Black Hawk's Avatar
Your bolt pattern should be 5-135mm.
Old Mar 30, 2006 | 03:56 PM
wandell's Avatar
Plus, my tires are 285's. BFG recommends a maximum of a 9 inch wide wheel for them.
Old Apr 6, 2006 | 08:46 PM
speeddemon13's Avatar
if i am going to get 35x12.5R16 shud i get 16x10 or 16x8?my friend has 18x10 on 35 and they stick out quite a bit but he has a 2006 f150 screw
Old Apr 6, 2006 | 11:27 PM
wandell's Avatar
I'd go with the 10 inch wide wheels. You are comparing apples to oranges with our trucks and an 06. They are two completely different vehicles.
