Pro Comp 6089 ?????
Old Feb 11, 2006 | 10:09 AM
rand17's Avatar
Pro Comp 6089 ?????
I have a 2005 FX4, I want to run the Pro Comp 6089 17x9 But I have seen some people say they will NOT fit, Will a 18x9 Fit?, also any Ideas on a 33" tire?, was kinnda thinking Pro Comp as well, Thanks
Old Feb 11, 2006 | 10:24 AM
wandell's Avatar
Ford changed the brake calipers sometime during the 05 model year which is causing fitment problems with some aftermarket 17 inch wheels. I don't know of any problems with fitment problems with any 18's. I would suggest installing a 2.5 inch leveling kit, 18x9 inch wheels (with 5 or 5 1/2 inches of backspacing) and 325/60-18 (33x13.00) tires.
Old Feb 11, 2006 | 10:37 AM
rand17's Avatar
Thanks, Im thinking I will use the AS 2.5 leveling kit, I guess my set up will be Pro comp 6089 18x9 then, Still need to decide on tires maybe Cooper?
Old Feb 11, 2006 | 11:06 AM
rand17's Avatar
Any sugjesting on what brand of tires for the 18x9, I kinnda want to stay with a 33" tire, im finding a limited selection,
Old Feb 11, 2006 | 12:09 PM
The professor's Avatar
what style of tire do you want. If you want an A/T you should look at Nitto, toyo, and BFG A/T's.
http://toyo.com/tires/tire_lines/off_road/opat.html
http://nittotire.com/tires_terragrappler.asp
You also may want to look at the mikey thompson ATZ if your going for an A/T. If your looking for an M/T then your best choice would be to go with a 17 unless you get a lift and get a 35 or larger tire.
Old Feb 11, 2006 | 01:25 PM
enormous's Avatar
I'm running 18 x 9 6089 with Toyo 35" AT on a 6" lift.
Awesome rims and tires on my 04 Crew.
Norm
Old Feb 11, 2006 | 03:22 PM
rand17's Avatar
Well after LOTS of checking it looks like the Pro Comp 6001 17x9 will fit my 2005 FX4, with Nitto 295/70/17 Grappler, Does anyone know of any fitment Problems with this set up?, Thanks
Also will install AS 2.5 level kit
Old Feb 11, 2006 | 11:01 PM
wandell's Avatar
They should fit with a leveling kit. Also, I believe Cooper makes Pro Comp tires. As for 33 inch tires for 18's, Pro Comp, Mickey Thompson, Nitto and Toyo make 325/60-18's.
