Hard Water & Chrome Rims
Old 01-09-2006, 04:30 PM
Doosty789's Avatar
I have sulfer water from a well, the kind that smells like eggs. Yeah it sucks but whats even worse is that I think its eating my chrome rims and handles. Does anyone else have that problem?? Anything I can use to protect besides the obvious.
Old 01-10-2006, 12:22 AM
FX4ME2's Avatar
I would check with someone that does water softner systems. good luck...
Old 01-10-2006, 06:28 AM
phillyford99's Avatar
I had the same problem and installed an in-line dual filter kit for less than a $100 bucks and it worked great. ZYou also need to run some polish over the rims after each wash.
Old 01-10-2006, 08:40 AM
05supercrew's Avatar
Use the Mr. Clean car wash kit to clean your car if money is an issue. Polish/wax your rims at least once a month. I have a water softner and it does wonders for the whole house.
Old 01-10-2006, 08:52 AM
jdew1920's Avatar
When we moved into our house it had a water softener but the outside spigots were not plumbed to it - maybe this is your case?
Anyways, I just plumbed in a line coming off of the softened water line to the line going to the spigots - added a shut off valve on that line, and another shut off valve on the line going to the spigots before the point where I tied in the new line. This way I can shut off the non-softened water line and open up the softened water line and I have softened water outside when I need it.
Old 01-10-2006, 09:05 AM
I plumbed everything in the house even the sprinklers because thats where most of the spots on my truck where coming from. It didnt elimanate all the spots but it helped a lot. The guy up the block from me had a small softner put in just to wash his Dodge hemi truck.
Old 01-11-2006, 06:01 AM
ShorgasmIII's Avatar
well from now on wax those 2 spots. at a minimum, when you wash, dry them immediately. hard to say what the damage is w/o seeing them first hand, but to remedy the damage on them now, try some steel wool in a hidden spot to make sure it doesnt scratch them (it shouldnt) that should remove the damage unless its pitted
Quick Reply: Hard Water & Chrome Rims
