question on tire width (sticking out)
Old Aug 8, 2005 | 02:51 PM
laxwarrior013's Avatar
Exclamation question on tire width (sticking out)
hey fellas, i got a quick question on backspacing and offset or whatever. I am not really knowledgable in this stuff yet so i sort of need a crash course. I was wondering what difference it made. Like i want a tire that will stick out past the fender of my truck, i love that look. Can i coontrol how much stick out by backspacing measurement and offest? If anyone has pics of nice fat tires like a 325/60r18 or something.. shoot me some pictures and let me know what your rolling on..
thanks guys
2001 ford f-150 screw 4x4
Old Aug 8, 2005 | 04:02 PM
JJG052590's Avatar
Banned
yup you sure can control backspacing depends you can buy backspacing things like 1/4 an inch i've seen up to 3 inch ones
Old Aug 8, 2005 | 07:42 PM
Exclamation further
so it it something like when you buy a rim it is pre determined how much of the tire will stick out by how much backspacing it has? or can you decide how much back spacing you wantsd rtegardless of the rim?
thanks
again anyone wityh pictures would be awesome
Old Aug 8, 2005 | 07:46 PM
Johngs's Avatar
Backspacing is a measurement of the wheel...if you have a different tire, on a different truck, but the same wheel, you'll have the same backspacing.
So if you want your tires to stick out, then you need to look at the backspacing measurements on the wheels you consider. Keep in mind there is a certain range you'll want to keep it within...I dont know what it is but you should find out.
Old Aug 8, 2005 | 10:52 PM
Exclamation 2001 ford f-150
I have a 2001 ford f-150 4x4 king ranch and i am looking for tires that will stick out about 2 inches. Does anyone know any good tire combos for this. IM looking for about 325/60r18
thanks
Old Aug 9, 2005 | 08:03 AM
wandell's Avatar
If you want them to stick out a couple of inches, you probably want a 12 inch wider wheel with around the stock 4 1/2 inches of backspacing. With a wheel that wide, you will probably need to lift the truck to prevent rubbing.
Old Aug 13, 2005 | 02:48 PM
Lightbulb thanks guys
thanks but where can i find a 12 inch wide wheel?? and would that tire fit on a 12 incher it is recommender for 9.5-10.5 but i can only find wheels that are 9.5 in wide that i can afford..or that i like.
thanks for the help
Old Aug 13, 2005 | 02:55 PM
Exclamation another thing
I thought of another thing just to ask..I have been looking at the 325/60r18 nittos on 18x9.5 eagle alloys. Do you guys think that this set up will look good, and if so do you guys think that the tires will stick out nice? i cant find backspacing measurments on these wheels.. thanks
Spenser
Old Aug 13, 2005 | 10:22 PM
wandell's Avatar
It all depends on the backspacing.
Old Aug 14, 2005 | 12:02 AM
Lightbulb one more question
the backspacing on the 18x9.5 is 4 5/8 do you think the 325/60r18 nittos will stick out and look nice!?
thanks
Old Aug 14, 2005 | 07:28 AM
for instance
like for instance, would a tire on a rim that is 9.5 inches wide, strick out the same distance as the same tire on a rim that is 10 inches wide if the two rims have the same backspacing measurment?
Old Aug 14, 2005 | 09:36 AM
wandell's Avatar
They are gonna be near even with the edge of the wheelwell.
A tire on a 10 inch wide wheel will stick out 1/2 inch farther than the same size tire on a 9.5 inch wide wheel if ***** wheels have the same backspacing.
Old Aug 14, 2005 | 03:31 PM
suggestions then
well with a 9.5 inch rim and 325/60r18 im only going to get evenb with the wheel well i dont really want that? what tire size and rims would you suggest? or does anyone have any that sound like i mnight like them..suggestions welcome!
thanks
Old Aug 19, 2005 | 10:16 AM
sgauthier's Avatar
you might want to ask your local law enforcement offical if it's even legal to have your tires stick outside your fenders. i'm sure it's illegal unless you plan on adding fender flares to cover it up. if you have to add the flares then why bother. not sure why you would want them sticking out anyways, your just going to stone chip the heck out of your truck and add unneccessary stress to your axles, studs etc.
good luck
Old Aug 22, 2005 | 03:01 AM
Rucraz2's Avatar
My set up
Well on my 05 I got Helo max 6 rims that are 18x9 and I got the new M/T ATZ tires size 325/60/18. The back spacing on the rims I believe are 4.5 or so. The tires stick out around 2 inches or so past the wheelwell. I will try and post a few pics when I get her cleaned up a bit. Later-Justin
