Largest tires
Old Jul 17, 2005 | 06:30 PM
USCG F150's Avatar
Largest tires
What are the largest tires that I can run on an `01 Screw 4wd without adding a lift??
Old Jul 17, 2005 | 06:50 PM
The professor's Avatar
Without doing anything you can fit 33's but if you crank up the torsions bars you may be able to fit 35's but you'll have a little rubbing. I know someone who has their torsion bars cranked and they have 305 maxxis buckshot mudders and have no rub at all. Those tires are 33.9 inches tall.
Old Jul 17, 2005 | 10:11 PM
GABoyinTroupCo.'s Avatar
I run 305/70R17 Maxxis Bighorn Mudders on my 2000 F-150 4x4 with nothing but the torsion bars cranked and I have no rubbing. The professor said his friends tires were 33.9 however mine measure an even 34 inches (that 1/10 makes a lot of difference when you are looking for bragging rights ). I have seen a girl in my hometown who is running a BFG 315/70R16 A/T on her 99 4x4 expy with no lift and no rub although I imagine it would have to rub if she were to take it offroad because in heavy offroading situations I have had mine bump the plastic valance.
Old Jul 17, 2005 | 10:26 PM
wandell's Avatar
Yeah, you can run 315/70-17's (35x12.50) by using the OEM 17x7.5 inch wheels. However, this is really pushing it. I would stick with 33's unless you plan on lifting the truck in the near future.
Old Jul 18, 2005 | 07:53 AM
USCG F150's Avatar
I should have taken my 33's off my jeep before I sold it!!!
Old Aug 8, 2005 | 10:20 PM
floutlaw1's Avatar
I have 305 70 16 MT Claws work and look great wish I had 10 inch wide wheels.
Old Aug 8, 2005 | 11:53 PM
BOSERO's Avatar
I am planning to run on 35 inchers as well without lifting my truck immediately. I plan to add on the lift a few months after buying the tires (after I save more money). So from previous posts, this is possible? Do I need to crank the torsion bars? How is this done? Do I need to regear? I will not be using my truck for off-road often... Maybe once a year only and only on rough dirt roads at most. Thanks for the help.
Old Aug 9, 2005 | 08:08 AM
wandell's Avatar
Yes, you can fit 35's on the stock wheels. Regearing would be a great idea. What engine, tranny and gears do you have. You may be alright if you have a 5.4 with 3.73 gears.
Old Aug 10, 2005 | 02:20 AM
BOSERO's Avatar
I have a 2003 F150 Supercrew Lariat 4.6L. I have no idea what gears I have but I really want 35" on my truck. If I need to re-gear, what gears should I consider?
I was thinking of getting 15x10 rims (AR Baja) and mounting the 35" on them. But I read somewhere that with the change in overall tire size, it will be advisable to upgrade brakes. I found break upgrades by Stillen but they require at least 18" rims. Are there 35" tires that can me mounted on 18" rims? Do I really need the brake upgrade?
Old Aug 10, 2005 | 08:05 AM
wandell's Avatar
A brake upgrade would be a good idea but not absolutely necessary. With a 4.6 you will probably want to regear with 35's. Also, a 15 inch wheel will not fit over your stock brakes. You need to go with 16 inch or larger wheels. As for 18 inch off road tires there are a ton available. Heck, they even make off road tires for 22 and 24 inch wheels.
