Tire Sizing
Tire Sizing
I have an '02 F150 Screw with the 16" wheels. Stock tire size is a 255-70R 16 and the awful Generals are in need of replacement. I tow a car hauler several times a year over distances up to say, 300mi. and was interested in a somewhat larger tire that the stock Generals (car hauler has no brakes, wanted more tire contact - stock looks anemic as well). Has anyone tried going to a wider tire with a lower aspect ratio that will keep the diameter about the same? Say - a 285-65 R 16 or something that gives a similar diameter (30dia. vs. 30.5 in this case) so that I don't have to worry about the speedo being off too much.
I don't want to negatively affect fuel mileage if I can help it - 1-2mpg might be the biggest hit I would want to take.
Is this possible or should I look at a different (17" - 18") wheel along with the tires?
Thanks folks!
-LS
02 Screw
XLT
5.4
Tow package
Thanks folks!
-LS
02 Screw
XLT
5.4
Tow package
You can easily go from stock size to the wider lower profile size. you won't notice the difference. If you decide to go to a 17 or 18 or even 20" rim/tire combo, then your tire choices will greatly improve, alone with nice new rims to look at!
rockafella
2002 F150 Supercrew FX4 rollin 22's
rockafella
