BFGoodrich All-Terrians
I have a stock height 2001 F-150 Supercab. I hate the look of these stock wheels. I want to buy some BFGoodrich All-Terrian tires and keep them on the stock rims (if possilbe) mainly I just want to give the truck a more beefy, off-road look. I do some off roading (mudding up in the cuts with friends) What size tire is the biggest I can fit in the wheel wells with out doing a lift? I may be able to do a 3" Body lift in the future. what size can i fit with the lift?
May I suggest looking at the bfg mud terrains, since that is your intended purpose for the tires. The 265 is the biggest tire I would recommend going with on your 2wd. If you get the body lift, you can go with 285's or 305's.
RockyJSquirrel, the reason you can fit 275's is because those are 60 series tires and street treads to boot. A 60 series is considerably shorter than a 70 or 75 series tire.
Originally posted by RockyJSquirrel
I disagree. My truck came with 275/60-17's. I don't want or need bigger tires, but there is room for more rubber if you got the gearing to turn them.
Also it would completely fill the wheel wells, but thats up to him if he wants that look or not.
