35" Tires w/ 3" body lift!?!?!
Yes, you can fit 35x12.50's on your truck with a 3 inch body lift. If you use a 10 inch wider rim, you will also have to crank up the torsion bars and/or trim some plastic on the front bumper's lower valance.
yes they will fit but you will have to trim a little as wandell stated. i put 35's on my stock 02 and had to trim a little off the valance. as for your performance.....you will feel a diff in shifting with stock gears for sure. i hit about 2200 in 4th gear at 55 and 1700 in 5th gear at 55. needless to say gears are in the mail along with a tru trac. good luck
I went down to my local Hummer dealership and picked up a set of hummer h2 factory take offs for 95 bucks a tire. Cant beat that with a stick. I am gonna go down to the shop next weeked to have my body lift installed and pics will soon to follow.
BF goodrich All Terrains ought to do the trick.
