Tire Size with no Lift
You can run a 285/75-16 (33x11.50) or a 305/70-16 (33x12.50) on stock 4x4. If you plan on keeping your stock 16x7 inch rims, I'd go with the 285's. If you think you may purchase some 8 or 10 inch wide aftermarket rims later on, I'd go with the 305's. Both will work with the stock rims, but the 305's are a little too wide and this will make the center portion of the tread wear a little faster.
