worped front rotos
worped front rotos
Hi
This is the secound time I have to replace front rotors. The first stock ones did not last 10,000 miles before the truck started shaking when breaking. I replaced them with raybestoes rotors and Quite stop ceramic pads. ran smooth for a year + . Any advice on the best rotors.
thanks
thanks
Well, as you have discovered, Raybestos does not make the best products.....Order Brembo OEM replacement units cryogenically treated. They are almost as hard as stainless steel rotors. Ordered through Diversified Cryogenics (they have a web site). Cost is about $100 each- it will probably be the last set you buy
