biggest tires to fit on 16's
What rims do you have? Are they the stock 16x7 rims? Is the truck a 4x4? If it is and you have the stock rims you can fit 285/75 tires with no problems. If you have some 16x8 rims you can fit some 305/75 tires. I'm not sure what the biggest tire you can fit on a 2wd is though. From what I've heard you can run a 285/75 tire but I'm not sure if they had to do some triming. I do know that 265/75 tires will fit on a stock 2wd.
1997 F-150 Lariat
Ext Cab Short Box
4x4 Off Road Package
3.55 Gears
265/75 R16 Uniroyal Laredo M/Ts
My 2 cents worth
If you're gonna stroke it, POWERSTROKE IT!!!
http://www.powerstroke73.homestead.com/
1997 F-150 Lariat
Ext Cab Short Box
3.55 Gears
My 2 cents worth
<font face="Verdana, Arial" size="2">Originally posted by unstable:
what are the biggest tires that would fit on 16 inch rims with no lift?</font>
Just make sure the rims do not have to much
negative offset or they could rub!
