Lug nut torque specs.?
So.it's a impact wrench attachment that limits the torque? Sounds like a great deal,even for Snap-on! I'll look into it,thanks!,,,,,98
98 F-150 4.6 Litre XLT2wd Ext. cab
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
custom dual exh/gibson rectangle tips/rear exiting.
color matched snuglid
Superchip!!!
Clear front corners
Stillen Quad light air dam,Sweet!!
Euro taillights
Cobra 75WXST cb w/weather alert
[b]Kenwood cd w/Radio Shack speakers,don't laugh it sounds pretty good
Viper alarm
On the way/wheels,tires, etc..etc.......
the monochromatic boogie is done,cool!.
Come see my new pictures@ www.my-f150.com
officialtomwaits.com
reverendhortonheat.com
WOW,what a cool site!
FENDER GUITARS ROCK!!!
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
98, there are several LS's that you can buy after market. There are several threads if you do a search. My axel wrap and wheel hop problems have become worse now that one tire won't spin. Cal Tracs are next!
Hey Flats Man,
I was under the assumption that the center sections of each unit were different. So,I just need to buy an LS gearset,and switch them out? Lemme know,thanks,,,,98
Something I just remembered!! Before you go too far with suspension mods,there may be a solution for all your troubles. There is a four link bolt in rear suspension available for these trucks.
I think it is Air Ride technologies that builds them. It does away with the leaf springs entirely,and has air bags for the spring assembly. They did an install and review in one of the three truck mags,and they said the improvement in traction and ride was astounding. The install is fairly involved,but nothing you couldn't handle,though...Give it a look see,,,,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
The Auburn Pro, as well as the other units, use your existing gear set but if you are thinking of changing gears down the road you should do it when you install the LS. I took some very detailed pictures of the install and when they are developed, I wll post them for you on this thread. I looked up the Air Ride Technologies unit last night and it looked great. The only down side for me would be the compressor and the complexity of the system. I would hate to be in the Keys an have a bag blow out while pulling my boat, if you know what I mean! The reason I am considering the Cal Tracs is that they are simple and pretty fool proof. Check them out at www.calvertracing.com. They have a set for the 97-2000 F150 that should get me off the line pretty good. Take care!
<font face="Verdana, Arial" size="2">Originally posted by 98SCREAMER:
So.it's a impact wrench attachment that limits the torque? </font>
It's a pressure regulator valve. Set it at XXXpsi & just use the impact wrench to spin the nuts tight. Drive ~50 miles then re-torque the nuts with a torque wrench.
If you have any intention of changing gear ratios, do as others have stated: change them when you install the LS differential. Auburn makes a good LS that is much better at preventing slip than "normal" LS designs. But they are not "serviceable". Once they wear out, you have to have the entire unit replaced. Other brands (factory) have clutch-packs that can be replaced for less $$ when they are worn-out.
Note: I have the Auburn, but I thought that you should know about the long-term ownership issues.
1997 4x4 Expedition- 4.6L, true dual exhaust w/Ravin DI/DO, K&N air filter, SuperChip, airbox mods, Edelbrock shocks, 285/75R16 BFG ATs, 2000 F150 "XLT" wheels, 4.10 gears, Auburn LS, Clarion In-dash CD player, Smitty Bilt push bars and nerf bars.
2000 4x4 F250 SD XLT SuperCab SWB- 6.8L, Offroad Pkg, Camper Pkg, 4.30LS, Tape & CD player, Remote Keyless Entry, Sliding back glass, tinted windows, 265/75R16 OWL tires, Smittybilt nerf bars & Line-X bedliner.
NoMo's site
I've got to do something either way,even with the three measily mods I have now the right rear spins(alot) I can't believe the person who ordered this truck with a class 3 hitch,didn't order the LS diff?
Anyway,,Thanks for the great info,,Flats Man & nomo!
Flats Man,,from what I've heard about the bags,they are nearly indestructable. You could use some coil-overs in place of the bags,too. Your right though,the weight of the compressor(and tank
) would slow your truck down. They would give you some traction,too
It's your truck,though,and I can understand keeping it simple and trouble free, thanks for the rear diff. info ,,,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
It's your truck,though,and I can understand keeping it simple and trouble free, thanks for the rear diff. info ,,,,,,98------------------
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
jarrettruelz88!
I just noticed you also have a Falcon! I have a 65 in the early stages of restoration. I'm thinking of going with the mini T-bolt route with it. Teardrop hood fiberglass decklid,fenders,etc..I'm hoping to stroke a 5.0 FI engine to drop in it. Maybe a beam axle,too,for the front! Wish it was already done! Saw some really fast Falcons at the all Ford drags in Columbus Ohio,,,,,98
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
Yokahama AVS/ST's
prarie tan/tan int.
K/N gen.II fipk
Superchip!!!
Clear front corners
Euro taillights
Viper alarm
