Big tires on stock x-cab 4x2?
Whats up guys? I have one little question. What is the largest tire that I can run on stock hieght? (w/o rubbing) Planning on new rims and tires, but no lift as of yet, not sure if ever. Thanks. Any Pics would help.
1997 F150 4.2 4x2 X-CAB Flareside Black
With all of that out of the way, lets get to the good stuff:
STEREO: Special thanks to Josh & Popps @ www.radio-active.org [*]H/Unit SONY Xplod ES CDX-M750[*] F/Speakers Rockford's Fanatic Q Components FNQ2514(THEY SUCK AND ARE NOW GONE)[*] NEW F/speakers are Memphis studios 5X7[*] R/Speakers Rockford's FRC1257 5x7[*] Sub:PheonixGold XS 10" in prefab box under bench seat w/o lift.[*] Memphis Amp ST3004 with front channels running seperates and rear channel running the sub. 5x7 running off H/U
I'm going to change my whole set up.
Under D'Hood:[*] Only a K&N filter.
Its lame, you have to start somewhere right? Trust me, I dream BIG.
On D'Skin:[*] Bug Deflector[*] One Vent Visior, other fell off[*] windshield sticker for www.radio-active.org [*] Hyperwhite headlight bulbs[*] Clear quarter & back glass for an even tint. Thanks Progressive![*] Custom door dings from some A$$HOLE in a parking lot on both sides.
At the moment I am running pretty stock on the outside, but the truck is clean and I have even BIGGER ideas for the outside. SC just got one step closer a lottery so maybe there is still hope.
LINKS:
www.roadarmor.com I said I have big dreams right?
www.nookie.com
LINKS:
www.nookie.com
thanks Dave. That helps alot. What is that inches? I know what wheels I want, but after some reading I'm not so sure that I want to go with centerline. Tell me what you think.
LINKS:
www.nookie.com
LINKS:
www.nookie.com
Those rims look great, havent seen them on a truck yet but they would look great with any tire......265 is a 32 I believe....fits fender well great....Good luck and dont forget to post pictures.....DAVE
1998 F-150, SC/Flairside,oxford white 4x2,4.6,auto,3.55s,nerf bars,cls 111 towing,bed liner w/mat,Eagle polished wheels 16x10 w/Yokahama Geolandars 315/75/16s,all plastics guards/bug shields,air raid/k & n filter, superchipped, duals out the back corners, flow master 3 chamber, snug top lid, f-150 online sticker back window-honk if you see me!!! Fabtech 3 1/2 lift,3" spindles, 3" body lift=9 1/2 inches of lift, lift lips.coverking dash cover, Lumi Logo's (front and rear), clear front corner lenses, muth mirrors,dash mounted CB, (TX Chapter requirement,lol),personalized license plates, Superlift traction bars,Image tail light covers (painted).and it still fits in the garage, yeahhhhhh
San Antonio
DWESSELS89@AOL.COM
San Antonio
DWESSELS89@AOL.COM
Guest
Posts: n/a
F150Degrees,
Try this out
To figure tire height use this formula;
Tire size example 265/75R/16
265 divided by 25.4x.75x2+16 = tire height
265/25.4x.75x2+16 = 31.649”
1998 (50th anniversary series) Solid Pacific Green Metallic F-150 XLT Supercab, 4.2L, Automatic (4R70W), 2WD, Limited Slip, 8.8 axle, Tow Pkg, 6' bed, Rear slider
Accessories added:
Performance:
Superchip / 4.10 gears / K&N air filter / Outerwear’s pre-filter / Ravin Z-55 muffler signal 3" in, dual 2.25" out
Suspension:
Edelbrock IAS shocks / Hellwig rear sway bar
Other accessories "added":
Color keyed outer grill / Perfect-fit bra / Stull polished grills / (4) 3A Racing 55 watt driving lights / (2) **** Cepek 150 watt driving lights, all controlled by SPDT switches / Clear corners / Fiberglass hood / Chrome F-150 emblems w/ side indicator markers / Trenz billet antenna / Power mirrors / Custom painted mirror housings / Muth signal mirrors / Driver side grab handle / White face gauges / Lloyd custom colored and embroidered floor mats Husky floor liners / B-Quiet sound deadener / Carr side steps / 3" rear seat lift / Black Max soft tonneau cover / Black Max cargo cleats / 3" body lift / OEM Chrome differential cover / Smart Park 2000 / (2) Lighted Ford logos / (2) KC HiLight 55 watt back-up lights / Viper 550 alarm (remote start) / OEM fender flares / Lift lips / BFG AT's 265/75/16 tires / (Custom painted OEM air dam, antenna cover, tailgate handle, slotted taillight covers, all plastic covers under the hood, and stone guards) / 23 tooth speed-O gear.......
Stereo:
still building......
Boston ProSeries 6.5" / Competitor 10" Subwoofer / Stock head unit with 6 CD changer.
Contact me at;
lmaox10@hotmail.com
Try this out
Accessories added:
Performance:
Suspension:
Stereo:
Contact me at;
lmaox10@hotmail.com
First off, F&B, you are intirely to damn smart for your own good! But thanks, b/c I never would have figured that one out. Do they make a 32/12.5/16 or would that be pushin it? I can get 10 inch rims with no problem, they will have to be made no matter what I go with. Basically I want a FAT DADDY tire for the wheel. Thanks for all the reasponses. Jeff
f150degrees,
pls. post some pics when you get your new wheels and tires,
I'm also looking for bigger tires for a 4X2, was thinking of the 17" rims from the 4X4 lariat, but very few manufactures make tires for those size rims, biggest i found was 265/70s.
I want the same height or higher than a 4X4 on a 4X2... whithout a lift... think its possible?
