lug nuts
Old Apr 29, 2003 | 12:39 PM
Snotes's Avatar
Question lug nuts
I am putting 1999 lightning rims on a 2001 F150 2WD Lariat. I wanted to buy some chrome lug nuts / locks. Does anyone know what the diameter, thread, and length should be? I can take these measurements myself but am not sure if they are metric or SAE.
Old Apr 29, 2003 | 01:39 PM
PhillipSVT's Avatar
not sure, 14x1.50 mabee. I think my 99 used 12x1.75.
Contact a local Gorilla dealer and they can help you out!
Old Apr 29, 2003 | 03:24 PM
Richard D's Avatar
Yep I think PhillipSVT is correct should be either 14x1.50 or 14x1.75 Gorrilla is the way to go in my opinion they have the better key for the locking lugs. If you have an Americas Tire or Discount Tire in your area they should have all those in stock they may hve to order the locks though. You may even be able to get them on there website but not sure about that. www.americastire.com then find a store locally on there search.
Richard D.
WHILE YOUR HERE CHECK OUT MY GALLERY:
https://www.f150online.com/galleries....cfm?gnum=2479
Old Apr 29, 2003 | 04:00 PM
powerstroke73's Avatar
NO ................. NO ..................... NO!!!!!!!!!!!!!!!!!!!!!!
Man, how many times has this been posted on this and other boards. It should be around Dec 99 when the did the stud chance and went to 14mmx2 NOT 1.75 or 1.5. Ford has used 2 wheel stud sizes since 97. 12mmx1.75 and 14mmx2. Since you're putting these on an 01 you need 14mmx2
Old Apr 29, 2003 | 05:46 PM
PhillipSVT's Avatar
at Least I was 1/2 correct, and correct where it matters for my setup.
Old Apr 29, 2003 | 06:56 PM
SSCULLY's Avatar
If you want the Ford Racing Lug nuts:
Trucks built before 29-NOV-99 : 12 studs, Ford Racing Part Number M-1012-C ( qty of 5 per pack ) list 12.95, www.oemfordparts.com price : 11.95.
Trucks built after 29-NOV-99 : studs, Ford Racing Part Number : M-1012-E, same prices both MSRP and from the web site.
Ford Racing catalog page 81, or check out the Ford Racing web site : www.fordracing.com/performanceparts
All the same, yes Phil had it correct, the truck has 14 mm lugs on it. The Gorilla catalog they almost look like Acorn nuts, that screwed me up for awhile, I thought some might have them, that I did not know about....Guess the drawing in the downloadable catalog from Gorrila is wrong. At least I hope it is only the drawing.....
Good luck with selecting Lug nuts for your truck, in my gallery there is a picture of the L lugs in the 3rd album, if you want to see what they look like.
Hey Phil...need some new skins ??? Got a set of F1s with 3,500 miles on them if you burned yours up already
Old Apr 29, 2003 | 07:12 PM
PhillipSVT's Avatar
how much SSCULLY????????
Old Apr 29, 2003 | 08:16 PM
Snotes's Avatar
Thanks alot, www.oemfordparts.com is good website. I'll probably order them from there. Selection at local autoparts stores is limited.
Old Apr 29, 2003 | 09:25 PM
SSCULLY's Avatar
Phil,
You got mail.
Steve
Old May 6, 2003 | 04:05 PM
shoboat90's Avatar
Just for the record. My truck was built in mid-2000 and my lug nut size is 12mm x 1.75. Found this out the hard way when I was having my new wheels installed yesterday and the 14mm x 2 lug nuts I suppled slid right over the posts. Make sure you test them before you buy them....
Old May 6, 2003 | 11:29 PM
SSCULLY's Avatar
shoboat90,
Mid 2000 as in 06/00 or mid 2000 model year ?
The plate on the door should have the build month and year stamped on it.
The cut off dates listed above are direct from Ford.
Lug nuts from site
PART NUMBER: M-1012-C
VEHICLE TYPE: F-150
Application
Wheel # M-1007-L189 1999 Lightning
1997-99 F-150 12mm Studs Only
Trucks built before 11/29/99.
1999 Lightning 5 pc
