Lug Nut Torque Specs
Old Mar 17, 2003 | 02:49 PM
jayhawker's Avatar
I recently purchased a 2003 King Ranch SuperCrew and now that I have a couple hundred miles on it I wanted to check the torque on the wheels. I looked in the owners manual and it said for 5 lug wheels 150 lb/ft torque, I thought that sounded high since the specs on our Crown Vic aluminum wheels is 85-90 lb/ft torque.
Does anyone have the correct torque spec, I don't want to damage one of my wheels, I imagine they cost an arm and a leg.
Jayhawker in TX
Astro Fiberglass lid
BedRug Liner
K&N Air filter
Old Mar 17, 2003 | 08:00 PM
01sport's Avatar
150 ft/lbs is the correct spec. Take a close look at the lug nuts and you'll probably see the torque spec stamped on them. The Crown Vic probably has smaller studs.
Old Mar 17, 2003 | 08:05 PM
grinomyte's Avatar
damn, 150? I barely have the strength (and traction ) to torque my 100 (98 f150) how the heck are you supposed to do 15?
Old Mar 18, 2003 | 07:43 PM
01sport's Avatar
Use a long torque wrench.
Old Mar 18, 2003 | 10:42 PM
Richard D's Avatar
I owna 97 and they are only 100 Ft. Lbs anyone know why they increased it so much over the previous ? I know they change the thread size form my 12mm to 14 mm is that the reason behind the increase those 14mm handle more toque?
Richard D.
Old Mar 19, 2003 | 08:13 PM
01sport's Avatar
The 14mm studs are the reason for the higher torque spec.
Old Mar 19, 2003 | 09:08 PM
Richard D's Avatar
Yep kind of figured that had to be it.
Richard D.
https://www.f150online.com/galleries....cfm?gnum=2479
Old Mar 19, 2003 | 11:03 PM
BigDeal's Avatar
Re: Lug Nut Torque Specs
Jayhawker.... If you don't mind my asking, where did you find the torque spec in your manual? I've been through mine a couple times and can't find anything relating to torque specs.
For anyone / everyone else out there, would you think my lugs should be torqued to 150 lb/ft since I've upgraded to 18" Lightning wheels with 14mm lugs? I'm curious, because I've been running them at 100 lb/ft. Anyone?
Old Mar 21, 2003 | 12:12 PM
jayhawker's Avatar
The tire torque specs in my 03 F150 manual is on page 184.
Hope that helps you. Jayhawker
Old Aug 27, 2010 | 11:39 AM
jagans's Avatar
150 ft. lb. Lug Nut Torque? Does anybody at ford think anymore?
OK, so the wife is out with your truck to pick up a dresser she found on Craigs list for a song, great deal. On the way home she gets a flat.
"Honey I have a flat and I am on the freeway"!!!
"No Problem dear, just jack up the truck and put on the spare"
"Is that hard to do?"
"No you just walk down the highway till you see a farm, wake up the old farmer and ask him if he has an 18MM 1/2 inch drive or larger breaker bar, Deepwell socket for same, and a 4 foot long pipe to loosen the lug nuts, Nothin to it"
I guess the guy at ford that designed the spark plugs for my 5.4 litre Triton designed the lug nuts too.
Old Aug 27, 2010 | 03:58 PM
All '97+ I wanna say are 150lbs+, 2001+ for sure is. Its for the brakes sakes. improperly torqued lugs can lead to warping rotors and unstable driving. Miles and miles of orbiting with offset weight balances, not good. I learned that the hard way.
Old Aug 27, 2010 | 04:43 PM
Richard D's Avatar
Negative
1997-2000 with 12mm lugs is 100-Ft.Lbs
2000- Current wiht 14mm lugs is 150-Ft. Lbs.
Old Aug 27, 2010 | 05:11 PM
kingfish51's Avatar
Originally Posted by Richard D
Negative
1997-2001 with 12mm lugs is 100-Ft.Lbs
2001- Current wiht 14mm lugs is 150-Ft. Lbs.
They actually changed in 2000. I believe some of the early 2000 models ha 12mm and the rest of the year had 14mm.
Old Aug 27, 2010 | 06:01 PM
Richard D's Avatar
Yeah I knew it was a mid year change, but I thought it was 2001
Old Aug 27, 2010 | 06:24 PM
Negative
Thanks for informing me .
