front rotors
You may need to remove the caliper bracket and the center hub nut and cotter pin but i am not positive
1997 F-150 XLT 4.6 REGULAR CAB, FLARESIDE PACIFIC CLEARCOAT GREEN 5-SPEED. WESTIN NERF BARS, POWER EVERYTHING,BUG SHIELD, EX-TANG SOFT COVER, BED LINER(FORD).
Better 1/2 : 92 Red T-Bird.
animal!!!
I juste replaced my rotors the other day (46000 miles) and I too had a problem getting them off. Spray something like lock free (whatever they call it) around the base of the rotors and then tap, pull, turn and jerk until they come off. This method worked for me. When you do get them off then take a wire brush to the area where they sit and put a small amount of grease in the same area.
I actually had a bear of a time getting the damn bolts off to pull the calipers away. Did you experience this? I actually stripped the bolt heads a little.
1997 F150 5.4L Supercab 4x4 "Off Road Package" Tow Package 46000 Miles
All stock except for an Alpine Stereo/CD Player, Soft Cover, Bed Liner, and a Custom Painted Bug Deflector.
The caliper bracket will have to come off (on a 98 at least), the two bolts are on the backside of the braket, you can't miss'em.
As for being rusted on, this seems to be one of the many plagues that the f150 suffers from. I too had a hell of a time getting them off (I still haven't managed to ger the rear drums off yet!) But, with a lot of Liquid wrench, WD40, and a host of other chemicals to soak in, if you still can't get'em off, you're gonna have to rely on the good'ol BFH tool. Don't worry, you'll get'em off eventually, because if I can do it, anyone can. Good Luck.
Black 98 F150-XL, 2WD, 4.6L Slappin Windsor Triton, 5spd.,
RegCab, Short WB, 3.08 rear, Air, Rear Slider, FM40 True Duals
Triton V8 Badges, Duraliner Bedliner, K&N, Ziebart, Castrol Syntec
HAWK Plus Bedcap, profile+ wrap-around bug deflector,
Blazer Neon-Blue projector fogs, custom look'n door cracks
Tinting: #4 RearCab & Bedcap Windows, #2 Cabside Windows
My Site
My Site
I took mine in to the dealer for front brakes. I don't know why, I guess it was still to new to me at the time. Dealer tried to sell me new rotors @ $89.00 per explaining that bound rotors are common on the newer 4x4's and would have to be torch cut off. I didn't like the sound of that so I left with new pads only. I have since been spraying pennetrant on every chance I get. I will however have a new pair handy when I attempt to get them Off.
97 F-150 XLT Ext.cab
5.4 auto o/d, 3.55 LS
Elct. 4x4, Tow Pkg.
Capt. Chairs, Console
Two Tone paint,Black on Silver, Rancho RS 5000's
Ford Bed Liner,Soft Tonneau
Bug sheild
Sony xplode CDX-600,MTX 325watt amp, 2 10" JBL subs.
Elct. 4x4, Tow Pkg.
Bug sheild
