I think Ive decided on MT/R's in 285...
Hey HARVESTER,
I've been thinking about the MTRs in a 285 as well. I checked Wal-Mart and they quoted me $201.95 a piece for the Goodyear Wrangler MTR in a LT285/70/17. Or $186.95 for the 265/70/17. Then it's $9.76 per tire for mount, balance, free rotations for life of the tire, road hazard, etc. That's been about the best price I've found.
Good luck with your decision,
Mark D
Mark D
Originally posted by Mark D
Hey HARVESTER,
Mark D
Hey HARVESTER,
Mark D
Josho66...Im not going with the 305's for 2 reasons. One, I think that the 305 is really pushing the limits for the stock pizza cutter rim and two is that I dont want to go with a tire thats like 34" tall. If I had 3.73's in the rear or like 4.10's..maybe. Ive got 3.55's and I dont want to be "geared" any taller. The 285's are like an inch taller than stock which is "acceptable" to me. Two inches taller would not.
Thanks MarkD....I never thought to try Wal-Mart...Ill let you know.
Gearing is quite simple actually if you think about it. Think of it like a ten speed bike. The lower the gearing, the easier it is to pedal but you have a limited top speed. Switch to a taller gear and it becomes harder to pedal but you go faster. (the taller the gearing, the lower the final drive ratio). Now put that in truck terms. Think of the motor as your legs. The higher you gear it, the harder the motor has to work to maintain any given speed. Now going up one inch in tire diameter (32 to a 33)would be about a 3% increase. So if you have a 3.55 final drive ratio, you would now have a 3.44 final drive. Going 2 inches taller would net you a 3.32 final drive, which I dont want. There are exceptions of course. Since our trucks will never hit redline in top gear, gearing higher may not net you any more top speed. I had my truck flat out pegged at 100 in OD and just simply didnt have the power to pull any higher rpm's. (about 3200 if Im not mistaken) Bigger tires (or gearing it taller) may see a lower redline in top gear becuase of power issues.
Confused yet???
Bottom line is that for my setup..(4.6, 5 speed. x-cab) 3.55 is about the highest I would want to go. Much higher would result in poor performance. Now if you have a 5.4 with 3.73's...well than maybe you could pull the 305's without losing much performance.
Or somethimg like that......
Confused yet???
Confused yet???
Confused yet???
Thanks for the info.
You should be fine. The 5.4 as an animal and will have no problem pulling the 285's. Although the 4.6 mated with the 5-speed isnt bad if your banging through the gears, but get up on the highway in OD and you really see the difference. Ive actually raced a 5.4 from a dead stop. Up until about 70 its pretty even...then its see ya. I may get a set of 3.73's next year to help out with the 285's.
By the way...whats the best price youve found?? The best I can find is $865, tax included.
