engine idle...help
Old Mar 22, 2001 | 12:15 AM
silverblade's Avatar
Post engine idle...help
Does anyone know how to adjust the base idle on these 5.4/4.6 2001 ? thanks for any reply.
Old Mar 22, 2001 | 11:33 AM
max mitchell's Avatar
Cool
Timing, idle, and mixture are non-adjustable. The computer controls this; reprogram the computer.
2000 F-150 XL, RC, LB, 5.4L, 4R70W, 3.55LS,
Class III tow, Payload #3, & Convenience pkgs.,
4-wheel disc/ABS, Chestnut/Parchment 40/60,
Ford bedliner w/Paintsaver & gas/wheel/spare locks,
K&N F.I.P.K. w/Outwears pre-filter, Superchip,
Dynomax ultra-flow welded 3" cat-back w/ 3" Y-pipe,
Hellwig front & rear anti-sway bars, Rancho RS 9000s,
Mobil 1, K&N oil filter.
Old Mar 22, 2001 | 03:28 PM
rocketir's Avatar
Cool
Mine started to stumble alot took it in and found that my idle air hose was NG. replace and its been fine since.
2000 f-150 red, XLT, 4x4, 5.4L, 3.55, sliding rear, 60/40, towing package??, ORP keyless entry.
Airaid FIPK, SI/DO Flowmaster 40's.
Old Mar 22, 2001 | 11:05 PM
Jwest's Avatar
Question
rocketir,
I've been having an idling problem since 5K. When I've taken it in they say it's just a characteristic of the engine (5.4) - no codes indicating problem. Thats fine but I shack in my seat when I stop at a light. Other identical trucks I've test driven from used car lots (probably lease returns) their engines purr like kittens. Was wondering if you could tell me more about this "idle air hose". Where would I find it? How would I know it was NG? Love my truck, but am frustrated with the rough idle.
Jwest
2000 XLT 4x4
5.4 w/ 13K
Old Mar 23, 2001 | 12:06 AM
Post
Rocketit,where is the "idle air hose" located at? Is there a test I can perform to find out its bad? please reply
Old Mar 23, 2001 | 03:45 AM
D.Kolb's Avatar
Wink
Talked to a Ford teck today he said Idle speed IS adjustable but Ford wont let them do it while under warranty. It's in the computer programing. Good luck!
2001 SuperCrew XLT- Bright red over silver, Captains, 5.4, 4x4, skid plates, towing pkg, 17"wheels, posi, Westin CPS tube steps, EXTRA FUEL CONSUMPTION PACKAGE!!
Old Mar 23, 2001 | 09:29 AM
36racin's Avatar
Talking
SILVERBLADE,
YOU ARE NOT ALONE. THE PROBLEM YOU ARE HAVING IS ONE THAT MANY OTHER PEOPLE ARE HAVNG WITH THEIR TRUCKS ALSO. CHECK OUT MY TREAD ROUGH IDLE/ ENGINE MISS FOR MORE INFORMATION. THERE ARE MANY FAITHFUL TRUCK OWNERS HERE ON THIS SITE AND WILL HELP YOU IN ANY WAY THEY CAN. GOOD LUCK WITH YOUR TRUCK AND IF YOU FIND ANYTHING THAT WORKS PLEASE LET US KNOW SO THAT WE ALL MAY TRY IT TOO. SOME FIXES WORK ON SOME TRUCKS AND THEN SOME DONT. THANKS
Old Apr 12, 2001 | 06:33 PM
DonW's Avatar
Post
Idle air hose, ?? never heard that one before, looked it up in the shop manual and found nothing...
Don W
97 F150 4X4 XLT, ORP, Tow Package,
CD-Changer, K&N, B&M shift improver,
PIAA fog lights, Weld Rims 17", 265 70LT AT/S, Flowmaster 40 series 3" cat back.
01 Expedition XLT, Generic.
http://home.pacbell.net/donw35/f150
Old Apr 13, 2001 | 10:06 PM
dvose99's Avatar
Post
My 2000 F-150 is at the dealers right now, the 4th time in 1 month for a rough idle (skip), was telling me it was normal, i don't beleive them, today they said they have found the problem, a faulty e.g.r. valve, any comments??
Old Apr 13, 2001 | 10:12 PM
1BADF150's Avatar
Post
hey guys this might help..I have had this problem w/ my 99 5.4 ..It showed up after I did a tuneup and progressively got worse..started to scare me cuz there was obviously something wrong w/ my truck ..took it to the dealerguess what? unbalanced power..#7 coil was burned out as well as wire and #4 wire was starting to go as well..so if you got a bad plug coil or wire the truck will idle rough and shake you in your seat cuz not all cylinders are running properly. I hope this heps
Old Apr 14, 2001 | 10:33 PM
Dae/MD's Avatar
Post
1BADF150,
Was your Check Engine light on? I would think if a coil pack goeas it'll set off the "Light of, What the heck is wrong now?", Check engine light that is...
- Dae
Old Apr 15, 2001 | 10:06 AM
Rj's Avatar
Rj
Lightbulb
If you guys read 36RACIN post on rough idle you will see that we have been through all of this. I can show you charts and graphs taken on injector fuel pressure,timing and compression readings, EGR tests all show within normal readings of ford specs.This is a problem that ford cannot fix. It does not show up in all 5.4 vehicles,but the ones that do have it will not be fixed. The only way to fix it is to file a claim with the DSB.Read your owners manual for information on the DISBUTE SETTLEMENT BOARD or you can beat your head against the wall and argue with ford and your dealership. IF you all file a case ford will wake up and try to resolve this problem. The choice is yours./ I have been there done that and WON!!!!!
Well it has been a few months since I have posted on this thread and I along with MikeInLA have beaten ford through the dispute settlement board.For two and a half years I have tried to convince ford I have a extremely rough idlier. They insisted it was a normal characteristic. They even offered me an extended warrenty.What will that do when they cannot and will not fix it. During my hearings with the DSB they asked if they could have a independent engineering specilist look at my truck. I replyed not a problem, his analysis was yes my truck does have a above the normal rough idle compared to others and is getting worse by the day. I am in the process of recieving a 100% buy back. Tax,license and accesories.This is due to the written work order I have from the dealer when I first reported this problem from day one. You must document your every move and conversation along with your legitimate verified problem.
