Low Idle with Air Cond. running
Old 04-12-2001, 12:46 AM
chris97f150's Avatar
Unhappy Low Idle with Air Cond. running
Anyone have suggestions? I have a 1997 4.2 V6. I just had the timing cover gasket replaced (by my mechanic, Ford wouldn't pay for it? They said that my truck doesn't have that problem, so it's not covered by the recall. Go figure???) and now I notice a low idle usually 500-700rpm only when the air cond. is running.
Old 04-12-2001, 10:59 AM
Post
Old 04-12-2001, 01:22 PM
KT's Avatar
KT
KT is offline
Post
My 5.4 idles 600-700 with ac on or off.
Old 04-12-2001, 01:26 PM
black f150 offroad's Avatar
Post
has the iac been plugged in?
Old 04-12-2001, 02:48 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by black f150 offroad:
has the iac been plugged in?</font>
Excuse my ignorance. But, how can I tell if it is plugged in? I'm not sure what the iac is. Thanks for your help.
Old 04-13-2001, 07:53 AM
Post
basically it is a round cylinder looking item on the top of the intake manifold near the throttle body, but if it has been unplugged for any length of time the check engine light should come on, basically check along the intake manifold to see if anything has been left unplugged, the cam timing could also be off as well, is there any hesitation when you first step on it, that wasnt there before? As the camshaft position sensor has to be removed when the front cover gaskets are done and if not put back in the proper timing can cause problems
Old 04-13-2001, 10:23 AM
Post
I haven't noticed any hesitation, but I will check it out. Thanks for the advice.
Quick Reply: Low Idle with Air Cond. running
