90mm maf????
Old Mar 29, 2001 | 04:13 PM
this-end-up's Avatar
Post 90mm maf????
Would the 90mm maf off of a 2001 Lightning fit on my 99 f-150?
99 F-150 Sport XLT Black supercab 4.6L auto 3.55LS
K&N filter, Velocity Tube, dual series 40 flowmasters
Ground Force 2 in. rear drop
Old Mar 29, 2001 | 06:03 PM
JMC's Avatar
JMC
25 Year Member
Post
TEU,
Are you asking if it will bolt up to your existing air inlet, probably not. With a few home made adapters it could be made to fit. Will the truck run? If it did, it probably would not run very well. Your PCM must be adjusted to the MAF or vice versa. A custom chip would help you do this.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks, MAC 8.8 Axle Girdle
BFG 285/75 R16 MTs,
Borla Cat Back, Hedman Headers,
Custom air intake system with modified
air box, Ported Throttle body,
Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Mar 29, 2001 | 08:19 PM
Matt90GT's Avatar
Post
The calibration is ALL wrong.
The lightning has larger injectors and a supercharger. Also they use a panel airbox. These are all factors in a MAF calibration.
Old Apr 1, 2001 | 02:22 PM
Post
Thanks for the feedback.
