Superchargers!!! Which one is better.
Old Feb 21, 2001 | 09:36 AM
Sniper's Avatar
Post Superchargers!!! Which one is better.
I have a 98 F-150 4.6L auto. I am looking to buy a supercharger soon. I have read a lot of the past posts on superchargers. I am wondering what the difference between the roots type and the centrifical type is. Thanks for your help.
Sniper
Old Feb 21, 2001 | 05:44 PM
98fword's Avatar
Post
Sniper,
Magnacharger.
elmo,
They're cheaper.
98 F-150 XLT 4X4 ORP Super Cab Short Bed, 4.6, Auto, 4.10's, Mag-Hytec diff. cover, Magnacharger supercharger, K&N FIPK, Superchip, Gibson single cat-back, 80/100w German head lamps, 80w amber fog lamps, Warn HS9500i winch with semi hidden mount, Wrangler dual battery kit with red & yellow top Optima batteries, 285/75R16 Goodyear MT/R's, 16x8 Center Line Hell Cats (JUNK WHEELS), Rancho RSX shocks, B&M deep aluminum trans pan, Rhino bedliner. Needs one more door.
http://hometown.aol.com/ninetyeightfword
Old Feb 21, 2001 | 06:18 PM
FordTrucks4Life's Avatar
Post
This isn't an answer, rather another question. I plan on getting a 2k1 f150 w/ 4.6 triton and manual trans. How much boost can i safely run on the stock internals, and will the tranny be able to hold up to the increased power? (i like to get on it hard from time to time so i know that'll factor in)
Old Feb 22, 2001 | 12:06 AM
elmo's Avatar
Post
What is the reasoning behind a centrifugal type, then?
[This message has been edited by elmo (edited 02-21-2001).]
Old Feb 23, 2001 | 12:28 AM
jamato_sk's Avatar
Post
I was reading in a comparision article that the shortblock on 5.4l engine (with the exception of lower compression pistons) is the same between regular 5.4s and lightning versions. This would seem to indicate the the 5.4l engine is a very stout piece. Abuse and neglect are the usual culprits of engine demise.
Crash,
Since you can't always believe everything you read....
can you or anyone verify the info I read about the short blocks of "regular" vs. "lightning" 5.4s?
