engine rattle noise , not lifters either hmmmmmm
Ok my truck has a new noise now, whopeeee NOT!!!!!! I ran some fuel injector through my truck today, helped i guess but something inside the engine didn't agree with it. I ran some cyclo fuel injector cleaner through it(yea I know cheap sh--) It makes this noise when you just first acclerate from a deap stop and when your acclerating hard but not floorin it. I understand the fact that it's hard to tell w/o actually driving the truck but any advice is very appreciated.
________________________
1991 FORD F-150 XLT LARIAT
4.9 L 6
4X2
EFI
GLASSPACK EXHAUST W/ STOCK CONVERTERS
2 1/4" BALL HITCH
DARK SANDSTONE/LIGHT TAN
FIBERGLASS CAP
265/75/15 TIRES(TOO BIG)
CAST ALUMINUM RIMS W/ BEADLOCKS
3.08 REAR AXLE???
____________________________
FUTURE MODS:
PERFORMANCE AIRRAID SYTEM
ELECTRIC FLEX A LITES
HIGH FLOW CATS W/ FLOWMASTERS
AMSOIL BY-PASS SYSTEM
BIGGER INJECTORS( P.S.I NOT SURE SIZE YET)
WHITE LETTERED TIRES
F-150_91
4.9 L 6
4X2
EFI
2 1/4" BALL HITCH
FIBERGLASS CAP
3.08 REAR AXLE???
FUTURE MODS:
F-150_91
Please post here when you find out what that noise is. My 2000 Lightning has done that exact same thing since day 1. The dealer can reproduce it but since they can't find a tech bulletin on it they said I have to live with it. Grrrr. It works exactly like your sound. Part throttle, no noise, WOT no noise, 1/2 throttle just before it shifts I get this rattle like noise from what sounds like the engine compartment. I would give anything to find out what causes that noise. I have posted before and it seems like no one has had a similar noise .
Could it be a abnormally noises PCV valve. I can hear mine rattle like hell sometimes while at idle with hood up. You can also hear it if yo uslightly blip the throttle while under the hood. I was able to really listen to the PCV vlave and the injectors by using a cheap stephescope that we had hear. You can buy the mechanic type that has long rod to it to reach more places.
Also check all your drivebelts and pullies. A loose pulley/bearing or fan clutch can create rattles.
