SVO Heads, Intakes, Roots Superchargers???
I thought about that Captain, but I like to do things one at a time so I know what makes it go. Also, cost is a factor. The heads list at Southwest Ford for $850/ea + a $100 install kit.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-Poweraid-3"
pvc air box mod
pvc air box mod
redlariet - see I like to do everything myself, so I wouldn't have to worry about labor charges, just take your time and don't let any of your helpers have beer.
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, 6 cd changer and a 12 premier sub, pilot ground searchers, borla SS split rear exhaust
soon: rear window covers, fipk, chip, rims
To All,
I searched for head swap and came up with this thread, which is several months old. Has anyone found the answer? Can the SVO 32 valve head, or the Lincoln Navigator DOHC (32 valve) be a direct swap on the 16 valve 5.4L SOHC. As others have pointed out, these are modular engines, so in theory is should be OK. Has anybody tried this???
Thanks all and best regards GoDogGo
2001 SuperCrew, Silver, 5.4L, 4x4, 3.55, Limited slip, Tow Package, 265x70x17, Sliding Rear Window, Tuff Spray-on Liner, Ravin Z55 Single-in Dual-out Sideswept, K&N FIPK, SuperChip, 1" Thick Sheepskin seat covers (soft as a babys butt), Nerf Bars, PIAA Superwhites, 9006 - 65W Fog Lights
Future mods - Roots Supercharger, Headders, revamped sterio system.
HI!... Well guys I called SEAN HYLAND MOTORSPORTS the other day to get some info on getting my heads on my 5.4 ported and polished. During my conversation, I was told that the SVO heads in the FORD MOTORSPORT book are pretty much the same heads that come on "99" - "2001" POWER IMPROVED 5.4's They have the bigger valves and redesigned cumbustion chambers. That's probably why if you read the fine print near the article in the FORD MOTORSPORTS book that it reads "1996-1998 ONLY". That's coming from my "2000" FMS book. SHM also told me that a STAGE 2 porting job on the "PI" heads will give you a 55H.P increase proven on their in-house dyno. In the near future JMC will possibly be installing a set of NEW, previously owned "PI" 5.4 heads on his "2000" 4.6. We'll let you guys know how that goes.
NEAL " THE H.P FREAK"
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, ***** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), fiberglass smooth wiper cowl (painted OXFORD WHITE), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, 3 AUTOMETER guage pods, filled with tranny temp, engine temp, and oil preasure AUTOMETER "PHANTOM" guages,custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP, BAUMANN ENGINEERING shift kit (on stage 5 setting)BYPASS CLUTCH CONTROL VALVE/PREASURE REGULATOR VALVE, ASP POWER PULLEYS, custom tig welded and ported JBA "JET BLACK coated headers, twin DERALE 16 INCH ELECTRIC FANS, PERMA COOL 14"/10" tranny cooler with 10" electric fan, custom ported (STOCK) throttle body, custom digital air intake temp sensor, custom ported TB intake elbow, relocated ATS.
FUTURE MODS : FORD SVT 24LB INJECTORS, CUSTOM SUPERCHIP FLIP-CHIP, BBK 75MM THROTTLE BODY, 80MM PRO-M MASS AIR METER, AADI F1 RAM AIR HOOD WITH CUSTOM FABRICATED RAM AIR SET-UP, CAL-TRAC TRACTION BARS, EXTRUDE HONED INTAKE MANIFOLD, SHM CUSTOM FUEL RAILS, SHM "RACE WATER PUMP, 90/10 FRONT CE SHOCKS, 70/30 REAR CE SHOCKS, BELL TECH 2/4 DROP, EXPEDITION CENTER CONSOLE, HARLEY DAVISON F-150, LOWER FRONT VALANCE (painted oxford white) and a KENNE BELL BLOWZILLA SUPERCHARGER.
ESTIMATED H.P TO DATE : 330H.P / 425ft/lbs of torque.
CURRENT PERFORMANCE : 1/4 MILE - 14.53E.T * MPH - 93.00 * 0-60MPH - 5.8 * 1/8 MILE - 9.2 * 60 FT - 2.0
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w stroked to 408c.i 625H.P (natural), 875H.P with 250H.P "BIG SHOT" N.O.S kit, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, CENTERLINE CON-VO PRO rims, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
