SVO Heads, Intakes, Roots Superchargers???
Old Apr 13, 2000 | 02:27 AM
JHL's Avatar
JHL
Cool SVO Heads, Intakes, Roots Superchargers???
Anyone running any of these SVO parts on a 4.6L? Ford has:
  1. ALuminum Heads
    (claim to give you 55HP)
  2. High flow intake manifold(claims 28 HP)
    The intake manifold is for a Stang...it would put the TB facing the opposite from stock F150...?
  3. ...and a roots type supercharger for the 4.6L:
THe SC cannot be used with the heads, and is also for a Stang.
OK Performance freaks...whaddaya say?
Our V8s are suppossed to be "modular", so why cant we put, or modify theses items to soup up performance?
Hope this UBB stuff looks good...
1998 Pacific Green 4x4 XLT, Xtra cab, Short bed, ORP, Willow Green interior, tinted windows, Superchip, K&N FIPK, Custom 3" aluminum tubing catback exhaust system with MagnaFlow Race Magnum muffler, Jacobs Electronics plug wires, Superior Transmissions Police Shift Kit, Eclipse Head Unit, Xtant 200W Amp, MB Quart 6.5", JL Audio 10" woofer, Alarm, and other goodies
whoops, had to fix it!
[This message has been edited by JHL (edited 04-13-2000).]
Old Apr 13, 2000 | 05:32 AM
Way2Big's Avatar
Question
JHL, where did you get the pics/prices? Is there a site where we can goto? Thanks!
'98 EB Expy
5.4L 3.73
Gibson catback
IPD Rear swaybar
Bilstein Shocks
Hood Guard
Manik Grill and Rear Tail Guards
PIAA Foglights
Stull Billet Grill and Bumper Inserts
Have, but not installed...
75mm Edelbrock TB
JBA Black Coat Ceramic Headers
Coming Soon...
Kenne Bell Blowzilla SC
Superchip w/above modifications applied
"Its Sooo Big...Shes Gotta to be Blown!"
Old Apr 13, 2000 | 09:50 AM
2001's Avatar
Thumbs up
Hey JHL!!
Check out under the header "SUPERCREW" a topic I have created called "4.6L Supercharger".
The information I have put in there will answer your question on superchargers. Up here in Canada, dealers and performance shops are installing "POWER DYN" superchagers on the 4.6L and WOW do they work hard.
Let me know what you think!
2001 Supercrew (4.6L supercharger on order)
Old Apr 17, 2000 | 10:29 AM
crash1's Avatar
Post
The research I have done indicates the intake manifolds will swap, save the passenger side inlet, EGR etc. In my mind, it appears some fabrication would be needed. The intake and supercharger should bolt up, however.
Who makes an intake to match the heads shown above?
'98 4.6 5-sp F-150
We've come for your Tundra.
Where we started.
After a facelift.
A 2" drop!
F-150online Photo Album
trixters-playground@excite.com
Truckin' Magazine!
Old Apr 19, 2000 | 11:52 PM
JHL's Avatar
JHL
Cool
Way2Big:
The website is an SVO dealer the address is:
http://www.mustangworld.com/ourpics/parts/parts.htm
Pics and some prices are found there!
I find it hard to believe that nobody has tried any of these performance items...anyone???
Old Apr 20, 2000 | 02:27 AM
wolvrin704's Avatar
Post
Looks like Mustang stuff to me. Won't work on truck engines.
97 F-150 S/C 4x4 ORP XLT 4.6 K&N , Flowmaster w/dual tailpipes, Bosch+4 plugs,Ford 9mm wires,Superchip.Patriot fiberglass toneau cover, Westin chrome step bars. Rear seat lift 4".
Kenwood 4011 stereo, USAcoustics 2150 amp, Profile electronic 3 way crossover, 2 10" IDQ DVC's.
FUTURE STEREO MODS:
Memphis components in front, Pioneer 3ways in rear, amp for the components, and a cd changer.
FUTURE PERFORMANCE MODS:
4.10 gears, Edlebrock shocks, supercharger, Airaid, power pulleys.
OTHER FUTURE MODS:
Ram Air hood w/functional ram air, suspension lift, 16.5" polished wheels, 35" tires, and sunroof.
Old Apr 20, 2000 | 01:03 PM
JHL's Avatar
JHL
Lightbulb
wolvrin704:
I agree with you on the intake and svo supercharger being intended for a 4.6L Muffstang, but our V8s are supposed to be "modular" so why can't we bolt on the heads?
Surely, some power-hungry f150er has tried them, or tried to fabricate the other items into his/her F150...
Anyone?????????
Old Apr 20, 2000 | 05:47 PM
BigRed2's Avatar
Thumbs up
mod-u-lar = Designed with standardized units or dimensions for flexible use.
That is the whole premise behind these engines, obtain the highest component reuse as possible. If you don’t believe check out this link on a CV head swap using Mustang GT heads which are actually used for 5.4L
F-150’s. Go figure, build it and it will run!
http://www.corral.net/Forums/Forum2/HTML/007517.html
99' F-150 XLT 4.6L SC 4X4 ORP LS
- K&N Air Filter
- Custom air intake from fender to TB
- Superchip
- PowerAid TB Spacer
- ASP Underdrive Pulleys
- Accel Coil Packs
- Rapidflow 3" single CatBack exhaust
- Fluidyne Trany cooler
- A.R.E. Hard Tonue Cover
- Duraliner bed liner
- Mobil1 5W-30
Old Apr 20, 2000 | 11:10 PM
frank ryan's Avatar
Post
All these parts will work on the trucks 4.6's. Mods will be needed for the intake an S.C. If you have a windsor 4.6 and what to use the svo heads you will need the valve covers off a romeo 4.6. Different bolt pattern.
Old Apr 21, 2000 | 11:00 AM
JHL's Avatar
JHL
Post
Frank:
That is what I figured, the SVO heads should be a direct bolt on, and the intake or SC would require some fabrication.
Hasn't anyone out there tried this swap? If not, does anyone know of a reliable source for information along these lines?
Old Apr 22, 2000 | 02:55 PM
redlariet's Avatar
Post
I am seriously considering the svo 2v heads. Mike Troyer tells me my chip can be programmed to handle them. The HP gains approach supercharger. Has anybody out there done this??? If not, I'll let you know what I decide.
97 Lariet-sc-4.6-4x off road-auto-3.55 LS-
superchip-K&N-Poweraid-3"
pvc air box mod
Old Apr 22, 2000 | 09:51 PM
JHL's Avatar
JHL
Thumbs up
RedLariet:
I have seen 2 different HP Projections for these heads 35HP and 55HP, what does Mike Troyer, say?
Does anyone know whats different about these heads? Is it higher compression? Better flow rates? Better combustion chamber? Or a combination?
Red...I for one want to know what you do, or if anyone has done this mod yet! Maybe Mike knows of some firsthand?
KEEP THIS TOPIC ALIVE!!!
[This message has been edited by JHL (edited 04-22-2000).]
Old Apr 22, 2000 | 11:57 PM
redlariet's Avatar
Post
JLH
I have some good friends at my local dealer. I'll give them first shot monday. I figure 35 to 55 reliable HP for under $2K isn't too bad. Will keep you folks interested posted. I'll start a thread if this happens.
Old Apr 23, 2000 | 12:49 AM
redlariet's Avatar
Post
JHL
sorry about that.
pvc air box mod
Old Apr 23, 2000 | 11:42 AM
captainoblivious's Avatar
Post
redlariet - I think I've seen the svo heads for well under 2k, maybe they where they iron instead of aluminum. They would be a nice bolt on though. Hey wouldn't putting headers on new heads then putting the whole thing on at once be kinda easier?
black 97' x-cab 4x4, 5 speed 4.6, black westin nerf bars, 6 cd changer and a 12 premier sub, pilot ground searchers, borla SS split rear exhaust
soon: rear window covers, fipk, chip, rims
