Engine number
Old Dec 30, 2000 | 09:00 AM
NunoPT's Avatar
Post Engine number
I need to know the local where is the engine number for my F150 4.2 that I import from US.
I live in Portugal, and that info. is very important for portuguese certification.
Nuno
fatimaf@clix.pt
Old Dec 30, 2000 | 09:28 AM
LeatherRebel's Avatar
Talking
NunoPT
Could you be a litle more specific regarding the "Engine Number". If you are refering to the VIN number that is stamped on the engine block, I have to admit that I do not know exactly where it is stamped. I am sure that someone will be along with an answer soon.
What year is your f-150? The year may be needed to locate the number. Also, there is usually a sticker that is on the drivers side valve cover that may have the info that you are looking for.
-Tills
2001 F-150XLT SuperCab, Silver, 4X4, AOD, 5.4L, 3.55LS, 17in Rubber, Sport Package, Bedliner, Sliding Rear Window and A partridge in a pear tree...
Old Dec 30, 2000 | 10:01 AM
NunoPT's Avatar
Post
Hi
I´m looking for engine block number (VIN?), I received the truck yesterday, and thats lot of dirt below the hood, its difficult to see anything(numbers) there.
Nuno
Old Dec 30, 2000 | 10:31 AM
NunoPT's Avatar
Post
Hi
Nuno
Old Jan 1, 2001 | 02:25 PM
Cowlady's Avatar
Question
If you do mean the VIN # (the # that tells you where/when truck was made,the weight rating, body style, engine size/type, etc.) try looking on your dash at the very bottom on the drivers side, from outside the windshield. In this country & Canada, they insert a little metal plate with the VIN # in that corner of the dash. It may be hard to see - it's almost where the dash ends but it should be visible if you stand above it & look down. Hope this helps! Tell us more about your truck too!
If you can't beat 'em, you're NOT driving a FORD!
Shovies PROVE that FORD'S are #1!!
'97 Black F150 XLT ORP 4X4
4.6L/auto/3.55 LS/power EVERYTHING,
nerf bars, 17" wheels, fog lights, trailer hitch w/electrical connector, front tow hooks, bed rail caps,
6 CD changer, lumbar support & 3 cow license plates - so far!
