2001 4.6L 20 H.P. Boost?
Does anyone know when the 2001 4.6L's are supposed to have the 20 H.P. increase? I pick mine up tomorrow, and it was built on 8/23/00. TIA
-AR
- 2001 F-150 XLT 4X4 Off-Road, S/C, FS, Black
- 4.6L Triton V8 (20 H.P. Increase)
- 5 Speed / 3:55 Reg. Axle
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Flowmaster 40 (Stock Setup with 4" Stainless Tip)
- Bugshield
- Bedliner
-AR
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Bugshield
- Bedliner
Supposedly the 20 hp boost is to begin with the first 2001 off the assembly line.
2000 F-150 XLT, 4x2, 5.4L Supercab, LEV, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, Heavy duty shocks, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, FORD bedliner, K&N air filter, mar-hyde rubberized undercoating, Modine climate filtration system, Bugflector II, Mobil 1 oil and filter, Build date 7/00
- Factory cab steps on order
Jackal,
Since you've picked up your truck have you been able to verify the upgrade to 240hp in the 4.6l? Can anyone verify which 4.6's are getting the extra 20 ponies?
Just curious - mine's being built next week and I sure would like the hp upgrade.
2001 F150 SCrew XLT 4x2 (on order - 7/26/2000) 4.6l 3.55ls, Toreador Red, Med. Graph. Int., Capt. chairs, 6-disc changer, moonroof, slider, tow package, bed ext ...
I wanted to bring back this topic because it occured to me that the old sae net HP rating of 220 was based on 4500 RPM. There are a number of sources stating the new sae net HP at 240 but at an RPM yet to be determined! Could we be looking at a possible marketing ploy here? WHEN the RPM rating comes out if it is anything other than 4500, we have been mislead.
Good point man...it wouldn't surprise me at all.
-AR
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Flowmaster 40 (Stock Setup with 3 1/2" Gibson Tip)
- Bugshield
- Bedliner
- Ventshades
-AR
- Keyless
- Premium Audio CD
- Mods.
- K&N Cold Air mod.
- Bugshield
- Bedliner
- Ventshades
Check the specs on a 4.6L Expedition. That vehicle has had the 240hp 4.6L since 1999. The changes are similar to what they did to the 5.4L that year to get from 235hp to 260, new intake manifold, heads with slightly larger valves, new camss, freer-flowing exhaust manifolds, and a new ECU program.
