Timing advancing
Old Aug 10, 2000 | 09:28 AM
grey ghost's Avatar
Post Timing advancing
Whats the best timing setting for a 1991 5.0 with a crane 488 lift cam with 292 duration.Has mass air and full length headers.
Old Aug 10, 2000 | 10:12 AM
OLE BLUE's Avatar
Post
Most would say 14, but you can eek a little more out of it if you are willing to run a higher octane. It's really all in what kind of gas you a willing to buy. I've heard as much as 16.
97 4X4 Flareside 4.6 5-Speed, Superchip, ASP underdrives, Airaid, Dynamax headers, Borla Cat-back, 5% Tint, 285/75/16, 16x8 Baha's, Rancho 9000's.
Soon to come:
3" body lift, 315/75/16 BFG KO's
Old Aug 11, 2000 | 01:53 PM
Former Sponsor
Post
Hi Grey,
Old Blue is pretty much right on the money.
The factory setting is of course 10 degrees BTDC on the 5.0, I would try starting at 13 degrees BTDC, and then go up in 1 degree increments from there. Pay very close attention to how it pulls at higher rpms in the higher gears, like 3rd & 4th, as detonation can show up there that sometimes cannot be heard, but will show in the seat of the pants with less pull, for example. The knock sensor pulls out a lot of timing anytime it is engaged, it can pull it out in 8 degree increments if the timing is too far advanced, which can spoil the performance of course. That is why we suggest checking this out thoroughly as you pull thru the entire rpm range in the higher gears, so you don't go too far and end up costing yourself power from a spark retard at higher rpms in higher gears (heaviest sustained load on the motor, pulling WOT for an extended period as happens in the higher gears).
Another factor of course is how that camshaft was installed, was it put in the block "straight up", without any advance or retard using offset keyway bushing or was it properly degreed in, as that will affect the power curve quite a bit. If it was put in advanced, then you use less initial spark lead of course.
Good luck!
Mike Troyer
Performance Products, Inc.
(540) 862-9515
Email: mtroyer@compuserve.com
First National F-150 Online Rally Event Organizer
[This message has been edited by Superchips_Distributor (edited 08-11-2000).]
Old Aug 14, 2000 | 10:08 AM
grey ghost's Avatar
Post
Thanks for for responding and I have notice that when fast acceleration or gettin on it aalittle it will pop so I think it's time to bump the timing alittle.
