HAND PORTING "99" ABS 80MM MAF?
Old Aug 8, 2000 | 03:14 PM
JMC's Avatar
JMC
25 Year Member
Post
Here is my opinion/experience on the truck sensors. Playing with them is free, until you go too far. If in playing with them you gain some power then that is the best bang for your buck.
Whit this one I was lucky/unlucky. The cutting of the tower did not work the way I wanted it to. I was lucky to be able to get it to work again. This will never stop me from trying something else again.
I have an other idea for the MAF. The stock (99-00) uses a tower that sticks out in the air-flow causing a restriction. Reducing this restriction will increase air flow to the engine. What set off my SES light was the extra air flow over the wires. If I can somehow remove the tower while still restricting the air flow over the wires to OEM specs then it should work. After a while cheating the OEM system this way will lean out the fuel ratio so I may have to step up the fuel flow. Larger injectors? Maybe...
Wish me luck
Jean Marc Chartier
PS. I lost the coin toss that is why my MAF was worked on. Otherwise it would have been Neal. His turn next time.
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, Shortened MAF sensor tower,
K&N air filter,
Superchips
Old Aug 8, 2000 | 06:19 PM
54regcab's Avatar
Lightbulb
How much for the 4.10s ?
Old Aug 8, 2000 | 08:30 PM
Y2K 7700 4x4's Avatar
Post
Whatever you do, do not replace that square tube with a round one. They are specifically designed square to match a specific square inch area with a ratio to many cubic inches -- and flowing air thru a cylindrical tube would waste effort trying to fit spherical inch area flowing in lineal inches.
Old Aug 8, 2000 | 10:10 PM
nomo's Avatar
Post
JMC writes:
This is very easy. All you need is something like a liquid rubber (that won't chip off) and coat the wire in the area where it would normally be covered with plastic. As you noted, it will probably run too lean. Larger injectors may not be necessary. All you may need is to increase the duration of injection. A chip mod could probably do the trick.
Old Aug 9, 2000 | 11:09 AM
mtucker's Avatar
Post
Y2K 7700 4X4- Still LMAO
Old Aug 9, 2000 | 07:47 PM
roadrunner's Avatar
Post
Any one Know - can the aluminum MAF on a 98 be "ported" - as per other posts ?
have not yet done it, but could be my next mod.
Tnx
rr
98 F150 S/C 4.6 2wd 50yr. Anniv. edition Vermillion/Silver,HD Tow Pkg, Boards, Vents, Lund Bug Chaser, LaBra Tonneau cover, DIY "breezer" Tailgate, 5th whl hitch, Tool box, 16" OEM Mag's,-BEEP,BEEP roadrunner floor mats.
Mobil 1 /Ford Oil filter/ K&N / air box mod.
In looks & go - Chevy - like a rock.
