cleaning a mass air sencer
Old Jul 20, 2000 | 04:06 PM
kevin 3636's Avatar
Question cleaning a mass air sencer
what should i use to clean my mas.alcohol is what i am planing to use.i am going to wait till i hear from some of you owners of the best trucks in the world and on.
Old Jul 20, 2000 | 06:55 PM
T Ellenberger's Avatar
Post
A friend of mine used spray carb cleaner. I saw him do it so I did it. The excess will evaporate in short time and it seems to work okay. He first tried it because he had a check engine light and the dealer said it was because he over oiled his K & N filter.
Use it when you are stopping for the day or at least an hour or so.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, Rancho RS9000 shocks
Old Jul 20, 2000 | 08:41 PM
Matt90GT's Avatar
Post
TB or carb spray works great. Just make sure that you let it dry before reinstalling it.
Old Jul 21, 2000 | 04:14 AM
kevin 3636's Avatar
Thumbs up
thanks for the info.
Old Jul 22, 2000 | 10:46 AM
Post
For the MAF we never took them off. Just sprayed the wires to make them clean. The carb spray will evaporate within minutes.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings, 265 70 16 tires, Rancho RS9000 shocks
Old Jul 24, 2000 | 12:14 AM
fordfixer's Avatar
Post
If you really need to clean it, use electric motor contact cleaner. It leaves no residue and is designed for electrical components.
Old Jul 24, 2000 | 10:24 AM
Triton46's Avatar
Post
I just did this over the weekend on my 91 Explorer. Very easy! Just unscrew the MAF and lift off, that easy. Take a can of carb cleaner and spray the two 'filaments' (they look like lightbulb filaments). Wait a few minutes to dry and then put it back in.
This was a fix for a problem I was having with the K&N. The K&N set off the Explorer's check engine light. After cleaning I haven't had a problem.
