"Check Engine" light
Old Jul 12, 2000 | 06:06 PM
T Ellenberger's Avatar
Post
I have changed my fuel filter twice and that bracket has been meaner than a junk yard dog both times. Place a rag on the frame around the filter to soak up the fuel that drips from the filter when you get it loos from the mighty bracket. I have used the Auto Zone plastic disconnect tools and they seemed to work okay but won't last as long as a good metal one.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings
Old Jul 13, 2000 | 12:58 AM
Boss96Hog's Avatar
Post
Changing your fuel filter is very important. I change mine every 2nd oil change. I also use a good fuel injector cleaner every 4th tank of gas. Clean injectors are the key to keeping your miledge and performance up. There is so much junk in these tanks at the gas station, you can't be too careful!
On a side note, get a locking gas cap too. Someone put valve grinding compound in my buddies truck and it wiped the motor.
Boss™
Just Ordered 2001 F-150 Lariat Wht/Slvr medium graphite leather, 4x4, SC, SB, SS, 99L 5.4L, 44E tran, 7700# payload, Class III Tow, 3.73LS, Skids, Capts chairs, 4W disc ABS, shift-on-fly, keyless, HD everything
Planned Mods:
Westin Chromed Stainless Nerf Bars, ARE LS II bed cover, Bedrug™, Gibson Swept Side Cat Back, K&N filter w/airbox mods, Headman headers, Superchip, 3" body lift with at least 33's, alarm/pager/auto start system, stereo system
Old Jul 17, 2000 | 01:37 PM
Michael Reschke's Avatar
Talking
Thanks to all for your feedback!
'97 F150XL 4.6L 5 spd 4x4 SC, Silver Frost Clearcoat Metallic,
K&N air filter, Access Roll-Up Cover, bug deflector, rear custom Ford mudflaps, Pioneer Supertuner CD, 4 Cerwin Vega Speakers. Future mods: Spray-in bed liner, shocks, Superchip, stainless rocker panel.
* 9/27/99 installed Factory Ford 60/40 seats from Sonny's
* 10/13/99 installed cat-back exhaust system with dual pipes out back, a Dynomax Race Magnum muffler, and 3 1/2' stainless slash tips.
* 3/9/00 installed BFG AT 285/75R16 on American Racing Altas 16x8
http://sites.netscape.net/iridektm/homepage
Old Jul 17, 2000 | 08:25 PM
REGULATOR's Avatar
Post
So how often really should you change fuel filter? I am about to hit 15,000 miles
My Check engine light came on, the truck is still under warranty obviously, but If it's routine maintanance I'm doing it myself.
I clean my K&N every oil change ( not over oiling the K&N) My check engine light came on after tank was almost empty ( fuel light was on) and then I went and fueled up.( it actually light up after I pulled away from gas station. Code did not clear even after driving a half tank out of it and refueling. ( same day) I just havent been able to get in to the dealer here to have it checked.
I think I'll just replace Fuel filter ( no telling how bad it is with the gas around here) and see what happens. I did try to manually clear code and after waking up the neighbors in the morning with alarm ( DOH!) when reconnecting the battery it was still there. ( PS I even removed Super chip and drove 50 miles/ 3 starts normal No change)
PS How do you get the computer to tell you the error codes with out a reader? I can do the Ignition key thing but what are the codes again please?
Y2K F150 4x4 XL Med Torredor Red
4.2 5 speed,AIRAID, SuperCHIP,
3.55 LS, Leer camper shell, bedrug,
Ranchhand Rover Brushguard 2X Off road lights
Tint/alarm/ aftermarket keyless entry/locks
2m radio, CB, 3 Scanners
regulator@f150driver.com
[This message has been edited by REGULATOR (edited 07-17-2000).]
Old Jul 18, 2000 | 12:33 AM
ddt101's Avatar
Post
Sounds like you checked the most obvious problems.
The next most obvious problem is REPLACE the EGO sensor. They only last 60-80,000 miles. It is a consummable item with a finite life and it will cause your CHECK ENGINE light to come on intermittently at first, then eventually the light will stay on.
It kills me that a Ford dealership will not come out and tell their customers to replace this item around 75,000 miles. For $50, you can't go wrong. It can be replaced in 15 minutes and will solve most of these complaints.
Good luck.
