Popcorn anyone?
Old Jul 11, 2000 | 12:59 AM
max mitchell's Avatar
Cool
same; I've read several posts with these results.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Old Jul 11, 2000 | 02:31 PM
rmarietta's Avatar
Cool
Thanks all for the input. Guess I'll turn up the radio and let this thread die.
'00 WHITE/GOLD F150 LARIAT FlareSide SC 5.4 Auto 3.55 LS
Black Westin Nerfs, White Prime Design BugShield,
White Vtech Taillight Covers, K&N Air Filter,
Sometimes Superchipped,
Leather Captain's Chairs (like a screen door in a submarine!),
and all the Lariat goodies
SOME SHOW and a LOTTA TOW
My am E, Fl *** Member of ??? Ford Group
[This message has been edited by rmarietta (edited 07-11-2000).]
Old Aug 31, 2006 | 07:33 PM
bobhf150's Avatar
pinging when at a stop or cruising 30mph
I recently about 1000 miles ago had a catback system installed using a Prochamber straight through muffler.When at a stop light or cruising at lower speeds I hear a pinging noise coming from my muffler should I be concerned?
Old Aug 31, 2006 | 10:33 PM
s1037s's Avatar
HOLY OLD THREADS, BATMAN! Just kidding. if the noise was not audible before you put the new exhaust on, then there may be a fitment problem( rubbing somewhere) causing a noise, or maybe the joint where the two systems meet are of differing materials, causing a joint seal and resonance problem. if it is a noise like marbles in a frying pan, maybe a baffle has broke loose( if there are no baffles, then maybe a peice of steel has come loose inside the muff) hope it helps.
Old Sep 3, 2006 | 06:23 AM
jbrew's Avatar
Hi!!
There was a TSB that had something to do with this awhile back. The heatshield around your Cat's was the culprit, but if I recall the noise was more prevelant at idle while in drive with the brakes applied.
Hope this helps ( :
P.S. I have more pics I took when I fixed this problem myself if interested - I'll post the one from the TSB.
Old Sep 3, 2006 | 11:46 PM
RaWarrior's Avatar
My Grand Cherokee still does it at 105k miles, I don't even notice it anymore. But my truck with only 91k is about as noise-free as you could ask for. No rattles, pops, clicks, nothing.
Old Sep 4, 2006 | 01:10 AM
DesertDawg's Avatar
Since we're resurrecting old threads, I might as well add my $0.05 (inflation )
My 2000 F150 4x2 (actually, it's a company truck; belonging to the big blue Q, like me ) makes the old "bacon frying" noises from about mid-May through early October. That's A/C condensate dripping on the y-pipe - I figure the pipe will last longer than the 4.6/tranny with the loads and speeds to which I subject them.
My DD '02 S'crew 5.4 4x4, on the other hand, has a bunch of tinny "crinkles" during the cooler months. Heat shields on the cats; which will probably start rotting off the first (if ever) time I decide to go run the beaches along El Golfo de California. Haven't done that in at least 25 years; so I'm thinking that I'm safe.
So put me down for one of each common noisemaker. Personally, I don't worry about either noise.
