KaN from a 97 4.6 to a 2000 5.4 exp.
Old Jun 15, 2000 | 02:42 AM
kevin 3636's Avatar
Question KaN from a 97 4.6 to a 2000 5.4 exp.
will a KaN fipk for a 97 4.6 fit on a 2000 exp. 5.4 . because i have a powerdyne coming and it does not use the fipk.so i will give it to my friends mom for him helping me put it on.let me know.i can call KaN but i allways forget to do stuff like that.
Old Jun 15, 2000 | 09:20 AM
RED Y2K SPORT's Avatar
Cool
Not sure, my Performance Products catalog, shows different part numbers for a K&N for Expedition and Explorer. Suggest you call a parts house that stocks K&N or call K&N and ask the question. Can Always pull the one off the EXPY and see if the one from the 4.6 will fit.
good Luck
Old Jun 15, 2000 | 09:54 AM
T Ellenberger's Avatar
Post
If you are referring to just the drop in filter, the answer is yes. If you were thinking of a K & N Gen II, or Air Aid, I will say I do not know.
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings
Old Jun 15, 2000 | 10:22 AM
cphilip's Avatar
Post
Yes as far as drop ins go. I am currently running my K&N from my 97 F150 4.6L in my 2000 F250SD 5.4L. Fits like a glove.
2000 F-250 Super Duty, SuperCab XLT, Oxford white with medium grey cloth captains chairs, 5.4L Triton V8 (260 HP - 345 FP Torque version!), 4R100 4 Speed Automatic Transmission, 4 wheel ABS, Deluxe Aluminum Wheels, Trailer Towing Package, Class IV Hitch, Reece load distribution system, Escort Sensor II Electronic Brake controller, Sure Stop towing skirt, "Westin" black powder coated step bars, "White-White" head lamps, Herculiner bed liner, ISSPRO Tranny Temp Guage, Excursion center console, Ford moulded mud gaurds, K&N Air and Oil filter, Amsoil XL7500 5W-30,Air filter minder.
