Hi 5.4 initial start idle
Old Apr 19, 2000 | 04:29 PM
Charlsve's Avatar
Post Hi 5.4 initial start idle
Does anyone out there on this excellent site have any comment about the starting revs immediately after the 5.4 engine catches? My 2000 instantly revs to around 1600 to 1900 rpm (hot or cold although SOMETIMES not as fast hot)and then comes back down slowly like it is supposed to. My concern is that in cold weather especially booting the engine up that fast may not be the best thing, although I imagine it does build oil pressure faster. My thinking is that a slightly slower uprev would be preferred. I've heard other 5.4's start and they seem about the same. From the outside the engine doesn't appear too goosed, but you can really hear the exhaust beat inside the cab. Just curious.
(I have not found how to set my profile yet, but I've a 2000 Lariat 5.4, 3:55, ext cab.---stock for now except for Century mid-high cap and FORD contoured running boards and bug deflector).
Thanks in advance.
Old Apr 19, 2000 | 04:33 PM
Ron Kaltenbach's Avatar
Post
Everything is perfectly normal. They all do this.
2000 F150 SuperCab, Short Bed, 4X4, ORP, 5.4L, Auto Trans, 3.55LS, Captains Chairs with power drivers seat, rear slider, class III towing package, remote entry with alarm and just about everything you can get on this truck. Added a Ford bug deflecter, floor mats, a K&N filter, a Dynamax Race magnum muffler, Superchip, K&N FIPK and Bilstein shocks.
Old Apr 19, 2000 | 04:41 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post
Even the 99's do it. I make it a habit to crank first, then put on the seatbelt, then adjust the tilt. By that time everything is back down to normal.
99 Lariat Normal Cab 2WD 120"WB 5.4 3.55LS, Tow,
Dark Toreador Red/Harvest Gold, Line-X
raoul_oba@hotmail.com
F150's of Virginia
Just cause we're from Virginia don't mean we're(well, you know)
Old Apr 19, 2000 | 04:58 PM
Dustoff's Avatar
Thumbs up
Completely normal...my 98 5.4L did this and so does my 2000 5.4L.
2000 F-150 XLT, 4x2, 5.4L Supercab, Superchip, Styleside, Black with silver two-tone, 3.55 rear, class III towing package with heavy duty cooling package, 4 wheel disk ABS, overhead console, sliding rear window, keyless entry, dark graphite interior, in dash CD, factory leather wrapped steering wheel, Pendaliner bedliner, K&N air filter, rubberized undercoating, cabin filtration system, Bugflector II, 5W-30 Mobil 1, engine build 10/4/99
Old Apr 19, 2000 | 05:38 PM
Reavis's Avatar
Thumbs up
Yup, mine too. I asked my usually right-on-the-money service writer about this once, he said Ford intentionally programs the computer to do this so the spec 5W30 oil gets up to the top of the engine faster after sitting at the bottom of the crankcase. Raoul is right. It gives me a little time to buckle-up and maybe make a slight boxer-trou adjustment before I make the jump to hyperspace.
The profile and signature info is right at the top of the thread. Just click on the word 'profile' and follow along.
2000 F-150 Lariat SB Supercab 4x4 Off-Road Pkg, Tow Pkg. 5.4L, 3.55 LS rear, Bright Red over Silver, Med. Graphite Guts, Rear Slider, K&N Filter, Cabin Filtration System, Superchip, Mobil 1.
Old Apr 19, 2000 | 05:54 PM
BLACKENEDFORD's Avatar
Post
4.6 does it too. Guess we all have to live with it.
Old Apr 20, 2000 | 10:11 AM
Charlsve's Avatar
Post
Wow, Thanks, all, for the comforting responses. And so quick, too (I'm not really too Internet-literate yet but I think this just conviced me how nifty it is for things like this)!
Like you, Reavis and Dustoff, I switched to Mobil 1 after 2nd oil change (I changed at 1600 and then at 28oo before putting it in at around 4000. Is there an aftermarket thingy to make the filter removal a bit less messy on a truck with the filter in the standard location? It's a bit hard to get to for a truck, but that doesn't bother me so much as the oil going kind of all over the front differential. Just wondering. Oh, I figured out the signature thing, Reavis, thanks.
2000 Lariat, 5.4, 3:55 l.s., 4wd ext cab, Chestnut/Gold, Century mid-hi cap, Ford short bug deflector, contoured Ford running boards and bedmat.
