Need help with "Service Engine Soon" light
Old Apr 15, 2000 | 02:28 AM
Ron Kaltenbach's Avatar
Post Need help with "Service Engine Soon" light
Need a little help with a problem. Yesterday I put in my Superchip with no apparent problems. Today I put a K&N FIPK on my 5.4 and now the Service Engine Soon light is on. Any idea what may be causing this? I believe it has to be something relating to the FPIK installation since the light was not on after installing the Superchip. Anyone else had this problem? Truck runs great, idles a little rough now.
2000 F150 SuperCab, Short Bed, 4X4, ORP, 5.4L, Auto Trans, 3.55LS, Captains Chairs with power drivers seat, rear slider, class III towing package, remote entry with alarm and just about everything you can get on this truck. Added a Ford bug deflecter, floor mats, a K&N filter and a Dynamax Race magnum muffler.
Old Apr 15, 2000 | 10:29 AM
b727capt's Avatar
Post
Since the K&N will flow more air I would disconnect the battery and turn on head lights. This will reset the comupter for the modification you made. Bill
Old Apr 15, 2000 | 02:40 PM
Sycoholic's Avatar
Cool
The computer might have temporarily seen a problem. Pull the battery terminal off for 5-10 minutes and then reconnect. If the light is still on, there is a problem that needs to be fixed and your truck will need to be hooked to a code scanner.
1997 F-150, 4.6, automatic, Dark Toreador Red, Supercab, Flareside, 4X4 Off-Road, Towing Package, Ford hvy dty rubber floor mats, Kenwood 10-disk cd changer, Kenwood am/fm cassette head unit, Ford bugshield, Chrome Grizzly Wrap Around Push Bar with 2 KC 100w Daylighters, Ventshades, Ford bedliner, Lund Premier tonneau cover, cab and bed professionally undercoated, Code Alarm Sure Start RVS remote starter, Ford alarm, Realistic CB with Wilson Little Wil antenna and Astatic power mic, ported MAF sensor, and Lots of TLC!! (Besides being an F-150 nut, I am a Ford auto technician.)
Old Apr 15, 2000 | 03:09 PM
Post
Think I may have found the problem. I took it off and discovered that the rubber gromet that goes in the intake pipe for the Mass Airflow Sensor is gone. Must have been sucked into the motor. Anybody else ever have that problem. That would explain the bad odor coming out the exhaust last night. Other than waiting until Monday and running over to K&N (I only live about 20 minutes away), are there any other solutions. Also, could that rubber gromet cause any damage to the motor? The smell is gone from the exhaust, so I am hoping it just burned up. Are there any possible after affects?
Old Apr 16, 2000 | 12:07 AM
E mac's Avatar
Post
Ron, these guys are right on the money. I installed the Airaid FIPK and the first thing the instructions said was disconnect the battery. Also, I saw a thread here where someone else had the same problem. They found out the K&N filter had too much oil on it and it got on the MAF. Just another thought.
Good Luck
2000 F-150 XLT Supercab 4x2. Bright red clearcoat w/gold two tone.5.4L, 3.55LS, class III towing, keyless entry, overhead console and captain chairs.
Ford bug shield and vent shades, Ford(duraliner)bedliner, Extang Black Max soft tonneau, Westin platinum SS nerf bars. Helwig rear sway bar, Flowmaster 2 chamber duel out the sides catback, Airaid FIPK, Superchip ( Well done Mike Troyer !! )
Old Apr 18, 2000 | 12:17 AM
Post
Found the problem. Took truck to dealer today and had to have Mass Air Flow Sensor replaced. No oil on it - tech just said it was bad - replaced it under warranty. Put my Superchip back in and it runs great. MAF Sensor may have been going out all along. Now I have to decide whether to put the K&N FIPK back on.
Old Apr 18, 2000 | 02:04 PM
jtray's Avatar
Post
My "Check Engine Light" started coming on about 2 weeks after I installed my superchip. I disconnected the battery to get it to go off and it came back on again within about a week. I talked to Mike Troyer who was a huge help and told me to try switching to good fuel i.e. Texaco. I was using 92 octane from a cheap gas station called "Astro" Since I switched to Texaco gas over a month ago the check engine light has stayed off. The dealer wanted $75 to check the code - so 9 cents a gallon more for better gas doesn't seem like such a bad deal.
1998 Ford F-250 LD XLT, 5.4 4X4, Midnight Blue/Grey 2-tone, Line-X, Leather, Kenwood Excelon, Rockford 600a5, JL Audio 10", 285/75/R16's, Flowmaster 40 series cat-back with 3" pipe, Chrome tip, Superchip, K&N Filter, Clear turn signal lenses, Superwhite bulbs from Fred@Sportbikes.net(awesome bulbs for $40), Rancho RSX Shocks.
Coming Soon: factory fog lights.
