mixing oils...
Old Nov 25, 2001 | 09:34 PM
ssanto's Avatar
mixing oils...
For those of us who cannot decide between 5w-30 and 10w-30.... what about mixing the two types? If you use the same brand, that shouldn't create any problems? right? anybody ever do this?
Old Nov 25, 2001 | 09:53 PM
bambino's Avatar
I don't have any evidence supporting my arguement, but my dad always told me this is something thta should *not* be done.
Old Nov 25, 2001 | 09:56 PM
Dvds's Avatar
Mixing means you get neither the full advantage of 5W30 or 10W30. Its pretty non committal. Your engine would survive this however!
Old Nov 25, 2001 | 10:26 PM
ssanto's Avatar
non committal? heh... that's what my girlfriend says.... BOTH of them!
... just kidding,... i couldn't resist
Old Nov 25, 2001 | 11:12 PM
FamilyRide's Avatar
I'd use on or the other. What does your truck call for? I'd use that. Mine calls for 5w-30, that's what I use.
Old Nov 25, 2001 | 11:41 PM
stephen muscio's Avatar
Different weight oils might not have the same amount of additives. Go to www.chevron.com and use the contact option. There tech section will be able to answer that question.
Old Nov 26, 2001 | 07:44 AM
LIGHTNINROD's Avatar
ssanto:
No problem--you just 'create' a mid-range viscosity 'oil'--been doing it for years--both 'on track' vehicles and daily drivers.
Dan
Old Nov 26, 2001 | 08:39 AM
PKRWUD's Avatar
Provided they are both the same manufacture, ie: Mobil 1, I don't see a problem.
Take care,
-Chris
Old Nov 26, 2001 | 06:40 PM
Ford4ever's Avatar
I a certain instant oil change place i worked at years ago which shall remain nameless...They would take all the half quarts laying around and mix them together. Every 20th or so oil change that lucky person would get a multi-grade, multi-viscosity, multi-brand oil.
While on the subject of oil, i usually use Castrol GTX. But what would you guys think of using an oil designed for big diesals like Rotella T or Mobil Delvac. There supposedly good for a few hundred thousand miles in a tractor trailer, would they provide good protectiong for a gas engine?
-Jon
